-   Tecplot (http://www.cfd-online.com/Forums/tecplot/)
-   -   Reading Tecplot *.plt files using TecIO.dll (http://www.cfd-online.com/Forums/tecplot/71715-reading-tecplot-plt-files-using-tecio-dll.html)
sbm_dk January 12, 2010 22:05
I desperately need to find a method to read xyz-data from Tecplot plt files. I believe Ive heard rumours that it is possible using TecIO.dll but have not yet seen a code snippet that illustrates how.
I am coding in C and C# but any piece of code in any language would be greatly helpful.
FB2012 November 14, 2013 07:26
Answer
An example can be found in the tecio source file archive dowloaded from tecplot support. It contains two parts the tecio source code and a program called pltview.
Reading the source code of pltview will explain how to do a plt reader.
In the main part of the program just turn on array reading by modifying the following part.
Line 594 change it to
ReportFileInfo(argv[CurFile], TRUE, TRUE);
Best regards
