February 15, 2010, 19:24 |
Tecplot airfoil.plt
anony
Hi Everyone,
I'm working on a CFD project involving multi-element airfoils. I wasn't able to find coordinates for any multi-element system, so I had to extract the coordinates of the airfoil example given in Tecplot. However, I'm not sure what airfoil system these coordinates refer to since they didn't specify any name and I need to know the name so that I can find some experimental data. If anyone knows what airfoil system the example refers to, please let me know. Thanks, bro |
February 16, 2010, 04:36 |
Vincent RIVOLA
Rep Power: 18 |
I don't know about tecplot model but if you want to simulate some multi-element airfoil, you should have a look at the hilift workshop at this page: http://hiliftpw.larc.nasa.gov/index.html you can get the model of the wing as well as grids, and experimental data. After the workshop you will even get access to simulations results. Hope this helps. Regards, Vincent |
February 16, 2010, 21:15 |
anony
Thanks for the input Vincent..however, they seem to have the coordinates for the entire wing rather than for the airfoil and given the size of the data they have, it might be difficult to extract the airfoil data..
Please let me know if you know any sources that have airfoil data! Thanks, bro |
February 17, 2010, 02:01 |
Vincent RIVOLA
Rep Power: 18 |
I did some computations on a three element airfoil in 2D using OpenFOAM. There is a thread in the OpenFOAM part of the forum.
You'll find the airfoil profile as well as more information at this adress: http://qnet-ercoftac.cfms.org.uk/ind...ription_AC1-08 Regards, Vincent |
February 18, 2010, 17:17 |
anony
Vincent,
Thank you very much for replying..the link you provided has everything I've been looking for..also, after looking at the images of the geometries you posted on your thread, I'm starting to suspect that the tecplot example refers to the same airfoil as you used because they look strikingly similar! Once again thanks. Best, bro |
airfoil, tecplot |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 12:48 |
Problem Exporting to Tecplot | Craig | FLUENT | 2 | July 15, 2008 23:21 |
How to read tecplot file witout tecplot ? | Pol | Tecplot | 11 | March 2, 2007 06:26 |
Using Tecplot for contours display | david | FLUENT | 2 | August 23, 2005 22:37 |
Tecplot can't read data file from Fluent. | stephen | FLUENT | 8 | November 21, 2001 20:27 |
