-   Tecplot (http://www.cfd-online.com/Forums/tecplot/)
-   -   Warping in Tecplot (http://www.cfd-online.com/Forums/tecplot/99486-warping-tecplot.html)
andreasp April 4, 2012 09:32
Warping in Tecplot
Sorry if this thread is misplaced, but I didn't really find a suitable forum for my question...
I am just starting to use Tecplot 360 for visualizing my CFD results. Is there a possibility to stretch a 2D data set (e.g. a slice) in the third dimension by a certain solution value? So the height of the resulting 3D surface corresponds to the this value.
What I mean is the "Warp" filter in Paraview.
Thanks for your help!
Andreas
SergeAS April 4, 2012 12:03
Andreas
Yes, of course. To do this, select the type of display "3D Сartesian"
and select the display in the third dimension variable in menu "Plot->Assign XYZ"
andreasp April 5, 2012 05:47
Thanks, this works if I have a purely/originally 2D data set.
But what if I have both a 2D data set (e.g. a 2D zone created by slice extraction) and a 3D data set (e.g. the original model)? Can I visualize both in the same plot?
The problem is that I have would have to assign different XYZ variables:
for the 3D data set:
X -> X
Y -> Y
Z -> Z
(because I want to see the model as it is)
But for the 2D slice:
X -> X
Y -> Y
Z -> U (or any other variable that I want to use for warping)
Can this be realized somehow?
SergeAS April 5, 2012 08:15
1 Attachment(s)
X -> X
Y -> Y
Z -> Z
X -> X
Y -> Y
It is quite hard do it in one frame. AFAIK only single assignment (X,Y,Z) is available in frame. What you say may be obtained by using a trick with two frames, with a transparent background at the front frame (see example).
http://www.cfd-online.com/Forums/att...1&d=1333628068
However, this approach seems to me to be too complicated. I can tell you step by step how to do it, if this option suits you. Maybe there's an easier way to do it
PS: If you do not need to combine the slice and the 3D view, you can simply create two frames on one page
scott_rumage April 5, 2012 18:57
I believe that SergeAS has provided the best solution to your question. An additional hint on how to have multiple frames in one view (with one having a transparent background) is provided in this tutorial tip on the Tecplot web site: http://www.tecplot.com/Training/Plot...ceControl.aspx
Regards,
Scott
