Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
ANSA Script
Old   August 8, 2017, 05:09
Default ANSA Script
Renuka
Renu123 is on a distinguished road
How do I automate cutting task using python script?
I am computer science student I have little bit knowledge about ANSA. I have many model and I want to cut it with plane. Currently I am doing it manually by loading each model and specifying point for cut using standard GUI utilits->cutting plane->xy,yz,zx cut.
For cutting each model required 3 points in order to get that points I am thinking to calculate normal to surface which will give 2 points.Could anyone tell me whether ANSA software has the function to find normal to surface, if does, where can i find the function. If not any suggestion how to do it.
Thank you
Renu123 is offline   Reply With Quote
Old   August 17, 2017, 09:07
greg.cfd is on a distinguished road
In order to generate the script for this task it would be very helpful if you could mention one by one the steps that you follow to do the job manually. All that functions that you are using.
Cheers
greg.cfd is offline   Reply With Quote
Old   August 25, 2017, 05:14
Renuka
Thank you for reply.
I am cutting model using standard GUI utilits->cutting plane->xy,yz,zx cut. Using python script I am able to specify plane and added it to model but problem is that how to calculate ox,oy,oz of each model automatically.
Ansa Script ganesh0481 ANSA 47 February 21, 2019 04:09
[Workbench] Run ICEM Script in Workbench Script MIZOR ANSYS Meshing & Geometry 9 April 4, 2018 07:45
Ansa Script Grigoriy_Ermolaev ANSA 3 April 20, 2017 04:50
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
[Commercial meshers] Output deck from ANSA for OpenFOAM use Kattie OpenFOAM Meshing & Mesh Conversion 10 February 2, 2011 07:46
