Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
ANSA Scripting
Like Tree3Likes
  • 3 Post By acurley31
Old   March 13, 2018, 15:48
Default ANSA Scripting
santosh prasad
sapnite is on a distinguished road
Hello all,
I am trying to set only desired PIDs to visible in ANSA, so as to perform penetration check command on those visible PIDs.
Can anyone guide me in doing this using python scripting. Basically I am asking for the command in ANSA which is to be used.
Thanks
sapnite is offline   Reply With Quote
Old   March 14, 2018, 18:14
acurley31 is on a distinguished road
See the attached example script. You'll have to change the filename to just have the *.py extension.
Here's a brief explanation of the idea:
1. First, collect all PIDs using the ansa.base.CollectEntities() function. For more information, refer to the documentation in the scripting library
2. Filter the PIDs to just get the desired. This is usually done via the PID name or the id associated with it.
3. Show only the desired PIDs using the ansa.base.Or() function. For more information, refer to the documentation in the scripting library
4. Perform the desired checks!
Alex
File Type: zip ansa_pids.py.zip (785 Bytes, 106 views)
Mrt23, Jost K and R prasad like this.
acurley31 is offline   Reply With Quote
pids, scripting, visible
How to rotate plane(360 degree) using ANSA scripting. Renu123 ANSA 1 March 14, 2018 18:26
What is the right file's extension format for Solidworks/Unigraphics to ANSA? Hypermesher ANSA 2 November 15, 2017 06:26
How to find center of model using ANSA Scripting? Renu123 ANSA 5 October 2, 2017 06:14
Ansa Python Scripting Renu123 ANSA 1 September 16, 2017 12:45
Ansa Python Scripting Renu123 ANSA 2 August 29, 2017 03:46
