June 12, 2013, 09:50 |
Max Size of free block
Hello everybody,
I use blocking to create a structured mesh in my 2D geometry. My geometry is basically a duct. In a particular area i want to create an unstructed grid. To achieve that I changed the blocktype (Blocking->Edit Block->Convert block type) from mapped to free. My question is now, how can i define the maximum element size in that particular free block? Is it possible to force ICEM to create rather rectangles than squares in that free block? Is it possible to declare a growing ratio of the quads from the edge? I thank you in advance for your help. Greetings bwiblue |
[ICEM] Icem cfd 13.0 | Ehab44 | ANSYS Meshing & Geometry | 46 | July 6, 2016 04:44 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[ICEM] Help with fixing imported IGES model | siw | ANSYS Meshing & Geometry | 24 | August 24, 2010 11:22 |
size function max size | Cz | FLUENT | 0 | January 7, 2009 05:08 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
