[ICEM] Problem in blocking an asymmetric Bifurcation with wall thickness |
July 9, 2019, 19:22 |
Rep Power: 7 |
hello everyone
I have a problem with ICEM! I want to create a structured mesh in a 2D-planar asymmetric bifurcation! the bifurcation has a wall thickness and structured mesh should be created in the wall too. can anyone help me with the blocking?? I tried different types of blocking by I failed in creating a good blocking. thanks in advance. figgggg.JPG |
August 13, 2019, 04:58 |
Gwenael H.
Rep Power: 20 |
There are different blocking strategies that you can use for a bifurcation. Simon had put together a nice tips and tricks for ICEM back in 2010 already (that you can find on this forum here : Simon's great tools (tips,tricks+ refinement)) In your case you can go for a quick quarter o-grid approach and add a boundary layer to capture your radius at the bifurcation. Have fun |
problem with creating artery thickness for FSI methode using fluent and mechanical | raminostadi | FLUENT | 1 | June 6, 2020 05:17 |
Wall thickness affects heat transfer rate | michal.s | FLUENT | 2 | March 18, 2018 09:19 |
VOF problem, liquid film thickness | Pedro24 | FLUENT | 0 | May 13, 2009 05:57 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Symmetric problem - Asymmetric prediction | Mark | Main CFD Forum | 14 | January 29, 2001 13:21 |
