[GAMBIT] wall
Old   May 5, 2012, 07:55
Angry wall
lyly
ezabille is on a distinguished road
hi all
what is the different between wall and wall shadow and interior and when should i use each one ?
and if i have assemply file and i have a wall between 2 different materials should i define it as a wall or interior ?
thanks
ezabille is offline   Reply With Quote
Old   May 7, 2012, 01:47
Far
Sijal
wall is the simple surface with fluid inside or outside.
Shadow wall is created when you have fluid on both sides of wall. So on one side you get the wall and on other side you get the shadow wall.
Interior is the domain/nodes which discretize your domain.
Old   May 7, 2012, 01:48
-mAx-'s Avatar
Maxime Perelli
*wall is a wall (should be used for surfaces which are limiting your domain if they are not used as other BC) >> per default gambit assigns automatically all peripherical surfaces as wall, if they are not already set
*wall shadow may indicate you, that you have connection problem in your mesh.
*interior can be used if you need to use an interior surface later in the post-process. In gambit all surfaces between connected volumes, are set as interior (or internal don't remember) but they don't appear in the BC list
*for your last question: if you set your surface as wall, then fluid will stop at this surface (v.n=0). If your both materials are fluid, then it is interior, but as I said previously, you don't need to set interior surfaces
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
