May 14, 2012, 18:10 |
Connecting of Blocks
Frank Weise
Rep Power: 17 |
Hi at all,
i have a fluid channel with some build-in components. Because of the complicated structure I've generate the blocks of the middle section first. After that I've the channels filled in with blocks. And now I've 2 connecting zones and I don't know the right way to connect the blocks together. This zone is located between the cylinder shaped form and the rectangular shaped form. Any hint is welcome! Additional I can send you the geometry and blocking files (210KB zip). Thank you very much in advance! Best Greetings Frank |
May 15, 2012, 02:48 |
Frank Weise
Rep Power: 17 |
... This was also my first idea. Unfortunately, I don't know which are the right ones. It's a fu**ing problem of geometry. Sorry, I ponder about it for several days.
Do you have time to take a quick look at the files? |
May 15, 2012, 10:05 |
Simon Pereira
Rep Power: 47 |
You can only merge verts to join the blocks if the topology where the blocking meets is the same...
In other words, if you have an ogrid on one side, you need an ogrid on the other side to merge... Other wise, just use a non-conformal mesh interface in your solver.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
[Commercial meshers] fluent3DMeshToFoam | bego | OpenFOAM Meshing & Mesh Conversion | 31 | August 16, 2023 09:04 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[blockMesh] connecting 2 blocks | Lexa | OpenFOAM Meshing & Mesh Conversion | 4 | November 20, 2009 05:47 |
Connecting blocks with multi-blocks methods | Sebastien Perron | Main CFD Forum | 3 | March 7, 2001 16:55 |
