[ICEM] Connecting of Blocks
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By PSYMN
Old   May 14, 2012, 18:10
Question Connecting of Blocks
Frank Weise
FrankW is on a distinguished road
Hi at all,
i have a fluid channel with some build-in components. Because of the complicated structure I've generate the blocks of the middle section first. After that I've the channels filled in with blocks. And now I've 2 connecting zones and I don't know the right way to connect the blocks together. This zone is located between the cylinder shaped form and the rectangular shaped form. Any hint is welcome!
Additional I can send you the geometry and blocking files (210KB zip).
Thank you very much in advance!
Best Greetings
Frank
FrankW is offline   Reply With Quote
Old   May 14, 2012, 22:38
Far
Sijal
Merge vertices....
PSYMN likes this.
Old   May 15, 2012, 02:48
Frank Weise
... This was also my first idea. Unfortunately, I don't know which are the right ones. It's a fu**ing problem of geometry. Sorry, I ponder about it for several days.
Do you have time to take a quick look at the files?
Old   May 15, 2012, 02:58
Far
Sijal
Ok. Send them
Old   May 15, 2012, 10:05
PSYMN's Avatar
Simon Pereira
You can only merge verts to join the blocks if the topology where the blocking meets is the same...
In other words, if you have an ogrid on one side, you need an ogrid on the other side to merge...
Other wise, just use a non-conformal mesh interface in your solver.
BrolY likes this.
CFD Online Users Survey
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[blockMesh] connecting 2 blocks Lexa OpenFOAM Meshing & Mesh Conversion 4 November 20, 2009 05:47
Connecting blocks with multi-blocks methods Sebastien Perron Main CFD Forum 3 March 7, 2001 16:55
