[DesignModeler] How to write the script in the ansys design modeler?
Old   June 4, 2012, 22:27
Default How to write the script in the ansys design modeler?
deddy chrismianto
deddy1973 is on a distinguished road
I would like to create the ship hull geometry paramaters automatically using ansys design modeler, but I know it is hard to use the design modeler standard tools (we know in the creating of parameters are available only for offset/moving and rotation). Also, I know that we can write the script to make a model in the design modeler, however I don't know how to write the script (especially: ways of script writing and the program language used). Please give me some recommendations
deddy1973 is offline   Reply With Quote
Old   July 22, 2013, 08:14
Tamara Annabelle
Marabelle is on a distinguished road
Hi!
I know it is quite a long time ago that you posted your question (approx. 1 year...) Did you find out how to write these scripts? I just found out this option under File->"write skript" and "run skript" but also I don't have any experience in the programming language jscript. Do you have any tips and tricks for me?
Thanks!
Marabelle is offline   Reply With Quote
Old   October 3, 2013, 17:33
Anon
merper is on a distinguished road
Perhaps this will help as a starting course:
This script will create the geometry specified. You may be able to reverse engineer it to learn some tricks.
http://www.sharcnet.ca/Software/Flue...eaExample.html
However, there is not much documentation from ansys on it. I've talked with the reps.
merper is offline   Reply With Quote
Old   October 4, 2013, 05:08
Tamara Annabelle
thanks a lot! I found a half-automatical solution now, with a saved script (with the "write script" function) and I duplicate my model and overwrite the sketches so I don't have to create the areas etc. and set the mesh sizing etc. again every time. I only have to set the conections to the new sketches and delete the old ones...
But by the time, I will try that tutorial, maybe it makes me life even easier. Thanks!
Design Modeler Boundary Condition natantyt ANSYS Meshing & Geometry 2 June 28, 2011 02:32
Ansys Design Modeler natantyt ANSYS Meshing & Geometry 1 June 24, 2011 01:00
Need some basic information for using Ansys Design Modeler pradeepmash ANSYS Meshing & Geometry 3 October 24, 2010 16:01
Ansys 12: Write def file downwars compatible? camoesas CFX 3 February 18, 2010 16:56
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
