[ICEM] What the hell
Like Tree1Likes
  • 1 Post By Gweher
Old   June 6, 2012, 18:41
Default What the hell
everdimension is on a distinguished road
So here is the simple geometry i've been practicing on:
http://dl.dropbox.com/u/55240438/ima..._innergeom.png
Here is what i get using one o-grid split:
https://dl.dropbox.com/u/55240438/im...icem_inner.png
And here is what happens when i try adding another o-grid to the inner channel with the offset factor less than or equal to 0.5:
https://dl.dropbox.com/u/55240438/im...m_innerbug.png
If i use higher offset value then it works fine.
So why is this happening??..
The project is attached.
everdimension is offline   Reply With Quote
Old   June 6, 2012, 19:28
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i think the problem is related to associations. i couldn't read your project. geometry neither. did you use icem 14 ? can you upload it again please. thank you
I get an error : Can't read surface model when i try to open the tin file
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 6, 2012, 21:15
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
As Ali said, it was just an error of association, I just associated your edges (of your fluid inner pipe and at the symmetry plane) to the curves and recomputed the pre-mesh and it worked fine.
Now you can just change the spacing near your boundaries. You should also have a look at the T-pipe junction topic .
diamondx likes this.
Gweher is offline   Reply With Quote
Old   June 6, 2012, 22:45
diamondx's Avatar
Ghazlani M. Ali
how about the version you guys used ?? could it be the reason why i couldn't open the project ? thanks
Regards,
Ali
Old   June 6, 2012, 22:54
Gweher's Avatar
Gwenael H.
I'm using the V14 and had no problem to open his file. Maybe you can export the project in a way that older versions of ICEM could read it, but I'm not aware of an eventual procedure.
Old   June 7, 2012, 04:01
So all you did was associate the three inner block edges to the inner symmetry curve, right? Thanks, i did not even think they needed to be associated. But it worked! Still it is a strange behavior.
Thanks again!
2diamondx
Yes, I am using version 14 as well.
Old   June 7, 2012, 04:31
Gweher's Avatar
Gwenael H.
Yes, I just associate the edges you didn't associate (to the symmetry curve). Don't forget that all association matters, and especially in your case where your bayonet-exchange model will need several C-grids inside each other.
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
