[ICEM] Mesh size within the boundary layer
Old   September 26, 2019, 09:43
Default Mesh size within the boundary layer
Lina
loverlose is on a distinguished road
Hi everyone,
I have a question regarding the mesh size within the boundary layer. I am currently working on a high speed model (Mach 4 and up) with Reynold's numbers in the order of 1E8. I was taught that one should aim for a y+ value of 1, which gives me a cell height of the order 1E-7. When running this, the CFX solver makes round-off mistakes resulting in negative volume elements, so this is not possible with my current resources.
I have also encountered convergence issues (oscillation around a certain point) but I have convergence with a minimum cell height of 1E-3 (I could still investigate if this could decrease a bit, at 1E-4 there is no convergence anymore).
My boundary layer thickness has a minimum of about 0 and a maximum of 3.7 cm. Currently my interest is the pressure distribution over the body, however in a later stage the edge temperature and the temperature profile within the boundary layer are also of interest.
My question is: what would be an appropriate amount of cells within the boundary layer (or an appropriate cell height) in this case?
Some background about the model: It is a half-domain, 2D model of a high supersonic-hypersonic missile with a Von Karman Ogive nose cone and a simple, cylindrical body (no fins, wings, anything sticking out).
loverlose is offline   Reply With Quote
boundary layer, convergence, hypersonic, mesh size
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
Mesh size for turbulence boundary layer tongx051 Main CFD Forum 1 October 20, 2013 15:19
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
