June 9, 2012, 08:52 |
y+ in practice
Robert
Rep Power: 15 |
Recently I have started meshing some simple geometries for heat-flow problems. I have encountered something like y+ coefficient. I understand basics of theory for this but I still have problems with usage of this. How should I use it? If I have simple turbulent flow in a tube of given diameter how can I calculate mesh size for it using y+? Can anyone explain it to me in the easy way? |
June 9, 2012, 09:09 |
Ghazlani M. Ali
Rep Power: 28 |
This can help you a lot :
http://www.cfd-online.com/Forums/flu...-diffuser.html http://www.cfd-online.com/Forums/flu...h-correct.html If yous search the forum in the y+ you will find a lot of threads about it. |
June 9, 2012, 12:53 |
Rep Power: 13 |
I would also recommend reading this: http://tinyurl.com/bs6rla7
June 9, 2012, 14:56 |
Robert
Rep Power: 15 |
I am familiar with this article and OK, I understand for which turbulence what value of y+ should be used. But my question is how can I calculate size of the first cell next to the wall using this value and obtain size in mm?
I have found CFD Online y+ estimator and there is sth like boundary layer length - is this length of the entire boundary layer or just let's say length of the turbulent part? In the simple pipe will it be its length? |
June 9, 2012, 18:33 |
Y+ should not ideally lie in the range of 5 to 30.. this is where laminar to turbulence transition takes place.
It should not lie in this range bcos capturing physics in the transition layer is quite a task in itself. So i generally run the fluent for around 50 iterations and then check the Y+ value. If Y+ has to changed then i come back to my meshing software to redo the mesh as required (to either coarsen or refine)..may be you can try this procedure.. Concept of Y+ calculation can be read separately... |
June 10, 2012, 08:51 |
#6 | |
Rep Power: 14 |
meshing advice, y+ coefficient |
Any free Best Practice Guidelines? | lakeat | Main CFD Forum | 3 | January 11, 2012 16:10 |
CFX best practice for external flows | siw | CFX | 5 | May 3, 2009 22:44 |
Modelling Airfoil Flow Best Practice | Ian | Main CFD Forum | 0 | October 3, 2007 07:19 |
who has ERCOFTAC Best Practice Guidelines ? | sarah_ron | FLUENT | 1 | September 27, 2004 07:17 |
best practice guidelines | novice | Main CFD Forum | 4 | August 12, 2004 11:52 |
