June 21, 2012, 02:57 |
Trailing edge mesh problem
Bharat
Hello everyone,
i am meshing an 2-D airfoil in a wind tunnel with y+=1 and unstructured mesh away from airfoil.i am facing problems while generating boundary layer mesh on the trailing edge of the airfoil. i am using wedge corner shape option here which gives me this ERROR: NODE XXXXX(increases whenever i choose this option eg 3342,3489,3571.... ) on the exterior boundary is merged. i will be very thankful if any other method is enlightened other than this method OR the correct way in approaching wedge corner option. thanks in advance bharat |
June 21, 2012, 05:59 |
Maxime Perelli
Rep Power: 41 |
may I see your decomposition in area of trailing edge?
In memory of my friend Hervé: CFD engineer & freerider |
June 21, 2012, 06:57 |
Bharat
Hey Max,
thanks for your reply, here i post you the decomposition area for trailing edge |
June 21, 2012, 07:02 |
Maxime Perelli
Rep Power: 41 |
try to do one more split along x from trailing edge.
Then don't "close" the BL at trailing edge, but extend it along this split.
June 21, 2012, 08:38 |
Bharat
thanks for the suggestion but, i apologize for not mentioning this:- as i have to create unstructured mesh near the airfoil(inside the box only) and continue meshing with structured(quad/map) away from the box in the wind tunnel. as extending BL along that split will create meshing problems further. is there any other way out?
June 21, 2012, 08:45 |
Maxime Perelli
Rep Power: 41 |
where should be the problem?
Can you send me your dbs file PS: Why are you decomposing your domain around your airfoil, as you would mesh it with hexa? And finally you mesh it with tri?
June 22, 2012, 03:33 |
Maxime Perelli
Rep Power: 41 |
ok since I cannot see what's going on the trailing edge, you may try to merge the domain with airfoil and the one behind the trailing edge.
Then split again axial from trailing edge and extend the BL here. The wake will be finer meshed
June 22, 2012, 06:23 |
Bharat
i am unable get it. i would be thankful if any picture is provided.
June 22, 2012, 07:39 |
Maxime Perelli
Rep Power: 41 |
Merge red square domain with blue one One it is done, split the new domain, along the black dotted line
June 22, 2012, 09:37 |
Bharat
thanks for the image, since i am new in using BL for simulations, i have one doubt:- is it okay to elongate the BL throughout the stretch. because i'll be using some turbulence models like S-A and SST, does it effect my result?
June 25, 2012, 01:00 |
#11 |
Maxime Perelli
Rep Power: 41 |
Since you are no more at wall proximity, I don't think it could be a problem (that's my opinion).
By enabling aspect-Ration algorithm, you can enlarge the BL away from wall Again all those stuffs could be preventing if you solve your trailing edge issue
June 30, 2012, 00:57 |
#12 |
Bharat
Hey Max,
thanks a lot for your comments that helped me a lot . my problem is solved. i made it into blunt(trailing edge) which was much easier to mesh bharat |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
ICEM aircraft mesh trailing edge difficulty | MontyR | ANSYS Meshing & Geometry | 4 | July 23, 2011 21:46 |
Meshing problem trailing edge of blade | ben-18 | ANSYS Meshing & Geometry | 1 | July 13, 2011 10:39 |
Multi element wing 3-d problem: trailing edge resolution | sriram042000 | CFX | 2 | March 13, 2011 05:44 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
