[ANSYS Meshing] Meshing Domain around blades
Old   June 23, 2012, 08:14
Default Meshing Domain around blades
Chris
chris85 is on a distinguished road
See image attached. I want to mesh the inner rotating domain with an inflation layer with a first layer thickness about 0.001 metres and a mapped quad surface mesh on the blade faces.
I have set inflation layer from blade surfacve to the edge of the rotating domain. Also have some edge sizing on the blades as well as an automatic method attached to the domain. I am getting a mesh with extremely large aspect ratio. When i try reduce number of inflation layers to control this or reduce edge sizing on the blades to control the aspect ratio it will not mesh the faces using a mapped method which I require.
Any tips which may helps.
chris85 is offline   Reply With Quote
Default domain jaho CFX 5 February 16, 2014 00:00
[DesignModeler] Meshing fluid domain through hollow pipes Cipherflak ANSYS Meshing & Geometry 5 March 8, 2012 03:29
[ICEM] Meshing Simple rotating domain in a External stationary domain sreenivas ANSYS Meshing & Geometry 0 January 26, 2012 22:57
Meshing around domain interface Tom S CFX 0 August 1, 2008 05:31
Meshing turbomachinery blade domain in Gridgen Hasham H Chougule Pointwise & Gridgen 0 September 3, 2007 08:33
