[ANSYS Meshing] Meshing a circular arc airfoil with close boundary |
July 6, 2012, 18:34 |
KB
Rep Power: 14 |
Hi, Please I have been tying to mesh this profile for some time.
I am new to CFD, I could not use blocking for the airfoil section. I used surface mesh for the airfoil section 1) I want to know if the mesh that I have created is ok as seen in the picture, the quality is 0.44. 2) I could not get the leading edge to be perfect curve as shown in the attached picture(I need guide on how to do this). If it is ok , I could not get a good results (lift (Negative) and drag are very high) when I ran the simulation in fluent. I will also need a guide on how I can use the blocking method to be able to compare my results. Thank you |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
[GAMBIT] Boundary Meshing on Splitting Geometry | tav98f | ANSYS Meshing & Geometry | 4 | June 3, 2010 16:16 |
simulating an airfoil using a moving boundary | Alejandro | FLUENT | 2 | February 9, 2007 23:46 |
