[ANSYS Meshing] Question about mesh generation for a wedge
Old   July 8, 2012, 11:29
Question Question about mesh generation for a wedge
lnk
lnk
lnk is on a distinguished road
I'd like to generate high quality mesh for a wedge by ICEM? (You can see it at the attachment. The flow is from left to bottom.) May I ask what kind of mesh would you recommend me to generate?
Thanks! I'm looking forward to your answer.
lnk
lnk is offline   Reply With Quote
Old   July 8, 2012, 11:38
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
easy geometry and very suitable for hexa mesh
Use blocking -> merge vertices and create y-grid.
You can share geometry of you want...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 8, 2012, 12:00
Question
lnk
lnk
Thanks for your answer. The mesh need to be inside the wedge. As you can see in the attachment picture. The hexa girds have bad quality at the up front part of the wedge. How could I improve that?
lnk
Old   July 8, 2012, 12:49
Far
Sijal
use Y-block or quarter o-grid.
Old   July 8, 2012, 12:50
diamondx's Avatar
Ghazlani M. Ali
check if your edges are associated to curves. if yes, turn on geometry, and see if you have surfaces there, click with right button then "solid".
Regards,
Ali
Old   July 8, 2012, 16:14
Question
lnk
lnk
Thank you very much for your answer. I tried to make the meshes again but still not able not generate high quality mesh as you did. Here is my mesh. You can see I always have problem at the frontal part (edge part) of the wedge . May I ask you how to solve this problem?
Best regards,
lnk
Old   July 9, 2012, 00:59
Far
Sijal
I guess in ur case angle is very sharp. You can use wedge elements (prisms) instead of hex for very sharp angle (Simon suggested in one of the posts on this forum) to control the quality.
Old   July 9, 2012, 01:42
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
There is still an importand difference between your blocking and the one suggested by Far.
Merge the 2 blocks at the sharp edge just like Far did.
flotus1 is offline   Reply With Quote
Old   July 9, 2012, 01:59
Far
Sijal
@flotus1 I didn't observe this difference.
@Ink : You must use Quarter ogrid or Y-block
Procedure is explained in detail here
http://www.cfd-online.com/Forums/ans...tices-why.html
http://www.cfd-online.com/Forums/ans...here-cube.html
Old   July 9, 2012, 17:13
Question
lnk
lnk
I think Flotus is correct. There is a significant difference between our meshes. I learnt your link but still not able to generate meshes like you. May I ask you to show your block?
Best regards and many thanks,
lnk
Old   July 9, 2012, 19:04
diamondx's Avatar
Ghazlani M. Ali
i'm making an ygrid in this video:
http://www.youtube.com/watch?v=nuiRkZqaEz4
start watching after 3:05 s
Regards,
Ali
Old   July 10, 2012, 06:48
Thumbs up
  #12
lnk
lnk
Thank you very much! I've done it!
[blockMesh] Problems in creating a wedge type mesh Joscha OpenFOAM Meshing & Mesh Conversion 28 August 3, 2019 07:59
ISAAC code mesh generation morteza08 Main CFD Forum 0 June 15, 2012 09:26
Non-conformal mesh question Jason FLUENT 1 January 12, 2005 16:17
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
3-d elliptic generation mesh Gang Sun Main CFD Forum 5 September 16, 1998 00:24
