[ICEM] The pre-mesh quality is very good but the mesh quality is bad
Old   July 27, 2012, 11:27
Question The pre-mesh quality is very good but the mesh quality is bad
lnk
lnk
lnk is on a distinguished road
Hi everyone,
Here is my question about mesh generation by ICEM. My pre-mesh quality is very good by the button 'check pre-mesh quality' . But after I convert it to mesh, the mesh quality is very bad by the button 'display mesh quality'. Should I go back to block to redo my block to solve this problem? Or I can trust the 'pre-mesh quality' and run the case directly?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 28, 2012, 08:08
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I also have this problem sometimes. You may check the Pre-mesh quality. It may also not good anymore. Sometimes if you save and close a project and then open again, something changes.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   July 30, 2012, 12:32
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
Hi.
You dont have to necessarily redo the mesh. You can very well trust the pre mesh quality. Its because, ICEM does not check the mesh with the same parameters in structured (premesh) and unstructured cases(dislplay mesh quality).
Anna Tian,
I have never witnessed anything like that.. I think something else is happening.
Ananthakrishnan is offline   Reply With Quote
Old   July 30, 2012, 13:58
Far
Sijal
I get this problem frequently. What I do is " I use to unchecke the solid and VORFN blocks" This always works for me
Old   July 30, 2012, 14:08
Ananthakrishnan.A.S
@ far,
is it?? but i read that it is not required to check the structured mesh quality after converting to unstructured mesh.. is it not enough if i just check the pre mesh
Old   July 30, 2012, 14:11
Far
Sijal
Question:
Response:
@ far,
I always found that the premesh quality is same as I get in Fluent or CFX
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
erroneous temps in conjugate model? sieginc. STAR-CCM+ 11 July 14, 2012 03:41
[ICEM] Tetra mesh quality before and after prism layer Chander ANSYS Meshing & Geometry 0 December 25, 2011 22:04
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
