[ANSYS Meshing] Modelling Heat transfer
Old   August 23, 2012, 09:00
Default Modelling Heat transfer
Lancashire
khuram87 is on a distinguished road
Hi all...
I am trying to simulate a flow in a ribbed channel
periodic boundary conditions are to be used
i have tried various meshing techniques including the size functions etc but still I am getting very high heat transfer values compared to experiments.
i am using k-eps standard EWT, with energy equation (k-w model apparently doesnt give desired velocity profiles)
if I make the cells too close to the wall, I get an error in fluent that "Aspect ratio is very high for some cells and the default code might not work".
The link to the problem description is (https://www.dropbox.com/sh/4u2y106krwo9knj/X7DaKglhp_)
Please reply ASAP
khuram87 is offline   Reply With Quote
Old   August 23, 2012, 09:25
Yon Han Chong
yonchong is on a distinguished road
Plot Graphic and Animations -> Contours -> Turbulence... -> Wall Yplus on surfaces you are trying to get heat transfer. If they are generally close to 1 or less you should be using Enhanced Wall Treatment with k-epsilion otherwise your heat transfer is going to be high.
Alternatively if you have later version of Fluent try Scalable Wall Functions as the EWT will give high heat transfer at high y+ (e.g. over 15) and Scalable Wall Function seems to give better results through wider y+ range.
Also use Relizable k-epsilion rather the standard model.
yonchong is offline   Reply With Quote
Old   August 23, 2012, 11:13
Lancashire
my y-plus values are around 0.5 and I have tried every model..!!
but the values are not right...may be there is a problem of meshing..!!
the mesh picture in the above link (Green one) seems to work but i dont know how to make such mesh..
Old   August 23, 2012, 11:24
Yon Han Chong
The link is broken. You might want to upload the pictures to this forum directly.
By the way, y+ 0.5 should be ok to use with Enhanced Wall Treatment.
Old   August 23, 2012, 12:02
Lancashire
http://imageshack.us/g/846/problemdescription.jpg/
this link works
Old   August 23, 2012, 14:11
Yon Han Chong
Is your model 2-D?
The green mesh look like Quad Dominant (or Hexa-Dominant) mesh depending on whether this is 2 or 3-D.
So where is the solid mesh if you are doing conjugate heat transfer?
Why are you saying your result is wrong?
Are you trying to calculate metal temperature or Heat transfer Coefficient?
Old   August 23, 2012, 16:46
Lancashire
my simulation is 2D...and i am giving a constant heat flux (1000 W/m^2) from both the top and bottom walls..
the main aim is to check how does the rib affect heat transfer due to production of vortices etc..this is quantified in terms of Nusselt number at the boundary of the wall where convection is taking place due to the flow...
the normalized nusselt number distribution between two successive ribs (Turbulence generators) is very high than the experimental values
http://imageshack.us/photo/my-images/407/85440146.png/
http://imageshack.us/photo/my-images/855/80504251.jpg/
Thanks alot for your cooperation
Old   August 23, 2012, 16:50
Lancashire
http://imageshack.us/photo/my-images/109/14004180.png/
these are the values for the normalized nusselt numbers which I should get..
but my maxima is 20..!!
Old   August 23, 2012, 17:10
Yon Han Chong
So how do you know the green mesh work?
Can you put your case file up?
Old   August 23, 2012, 23:17
Erik
evcelica is on a distinguished road
How are you calculating nusselt? I've never used Fluent but in CFX the adjacent wall temperature is used to calculate HTC, not bulk temperature,so it gives MUCH higher values than published data which uses bulk temperature.
evcelica is offline   Reply With Quote
Old   October 18, 2012, 01:53
A7A
AHMAD
A7A is on a distinguished road
Have you checked the reference values you are using like length which is must be the hydraulic diameter of the channel, and the reference temperature.
A7A is offline   Reply With Quote
ansys, heat flow, k-epsilon model, mesh and grid, periodic conditions
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Modelling Heat transfer between stack and gas in Thermoacoustic Chirag2302 FLUENT 0 April 24, 2012 01:14
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
Modelling combustion and heat transfer Tudor FLUENT 4 May 9, 2005 07:02
