[GAMBIT] internal 2D wall in 3D model?
Like Tree1Likes
  • 1 Post By -mAx-
Old   September 10, 2012, 10:56
Default internal 2D wall in 3D model?
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I'm trying to simulate a double helical impeller: is it possibile to have 2D internal wall inside a 3D model?Or Do I have to assign a thickness?
I assigned the impeller faces as wall, but these are eliminated into fluent as they are "unreferenced".
See attached picture.
Thank you
Daniele
ghost82 is offline   Reply With Quote
Old   September 11, 2012, 00:52
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I think you forgot to split your volume with the helicoidal surface.
Just try to move (not copy) the blue surface with any translation-vector. If you succeed then, the surface doesn't belong to the volume. And this is what gambit (fluent) expects.
So split the volume with the surface
ghost82 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 11, 2012, 03:25
ghost82's Avatar
Rick
Thank you very much Max, it worked
Daniele
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 13:57
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 04:36
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 11:31
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
