September 9, 2012, 09:35 |
Boundary layer O-grid assistance
Stuart
Rep Power: 25 |
I'm trying to get an O-grid to wrap around some wall-mounted cubes but I cannot get an O-grid to then also continue along the surface wall. The image shows (2D sketch of a 3D geometry) the current O-grids around the cubes (1) and the O-grids around the cubes and surface wall (2) that I'm trying to get. I thought selecting the fluid domain blocks and wall surface would work but clearly not. No combination of blocks and faces that I select will give me what I'm after. The *.tin and *.blk files are attached. Any help is welcomed. Thanks. |
September 10, 2012, 09:40 |
Stuart Buckingham
Rep Power: 25 |
Like this?
September 10, 2012, 11:51 |
Stuart
Rep Power: 25 |
That's the same mesh I could get. Where I would like to go from there was not only to wrap C-grids over each cube but to then extend them over the entire surface. Therefore, the refinement in the C-grids to capture the boundary layers on the cubes would also be captured on the ground surface as well. I cannot see your files until tomorrow when I get back to my ICEM computer. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Probems in Gambit: trouble linking two faces when a boundary layer is applied | Kathryn39 | ANSYS Meshing & Geometry | 1 | August 8, 2012 13:11 |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 09:47 |
LES- first grid point in boundary layer, y+ | sina | Main CFD Forum | 0 | February 3, 2011 09:26 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
