[ANSYS Meshing] dynamic mesh airfoil
Old   September 24, 2012, 09:22
Default dynamic mesh airfoil
mohsen
mohsenz_136 is on a distinguished road
hello I want to simulate accelerating motion of the airfoil by using dynamic mesh.airfoil accelerates linearly after static position. I've divided domain into three interior. interior 1 is boundary layer mesh near airfoil edge . interior 2 is un structure mesh and interior 3 is structure in far field . i want to fix interior 1 and 3. i used macro define C-G-MOTION i have some question
1- how can i move wall with interior 1 without interior 1 and 3 deformation
mohsenz_136 is offline   Reply With Quote
Old   September 24, 2012, 09:57
cfd seeker is on a distinguished road
The zones which don't get deform in dynamic mesh are defined as "Static" while the zone which gets deform is defined as "Deforming"
cfd seeker is offline   Reply With Quote
Old   September 24, 2012, 11:49
By this you mean Mach no is changing with time?
Old   September 24, 2012, 12:48
mohsen
acceleration of airfoil is 10 g and mach increase from o up 1.5 and initial of velocity is zero. boundary layer move with airfoil and it's mesh does not deform
Old   September 24, 2012, 21:23
Linear acceleration is 10 g? If airfoil is just linearly accelerating then I wonder what type of UDF/macro you have used to define its motion because in normal case when airfoil is static and air is flowing through the domain built around it is just like an airfoil moving through the static air. So I guess you have write UDF to continuously change the Mach No during iterations process isn't it?
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
dynamic mesh airfoil oscillation aamer Fluent UDF and Scheme Programming 0 January 25, 2011 07:29
[mesh manipulation] Dynamic Mesh Diffusivity Problem dancfd OpenFOAM Meshing & Mesh Conversion 0 August 29, 2010 11:50
