September 10, 2012, 10:56 |
internal 2D wall in 3D model?
Rick
Rep Power: 26 |
I'm trying to simulate a double helical impeller: is it possibile to have 2D internal wall inside a 3D model?Or Do I have to assign a thickness? I assigned the impeller faces as wall, but these are eliminated into fluent as they are "unreferenced". See attached picture. Thank you Daniele |
September 11, 2012, 00:52 |
Maxime Perelli
Rep Power: 41 |
I think you forgot to split your volume with the helicoidal surface.
Just try to move (not copy) the blue surface with any translation-vector. If you succeed then, the surface doesn't belong to the volume. And this is what gambit (fluent) expects. So split the volume with the surface
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; September 11, 2012 at 03:38. |
September 11, 2012, 03:25 |
Rick
Rep Power: 26 |
Thank you very much Max, it worked
Daniele |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 04:36 |
Wall Treatment of User defined Turbulence Model | Yang Chung | FLUENT | 0 | August 23, 2008 11:31 |
