[ANSYS Meshing] Named selection
Old   September 16, 2012, 08:38
Default Named selection
Rohit kumar Mittal
rkmittal1108@gmail.com is on a distinguished road
Hi
i would be very thankful to all if there is anyone to help me in sorting out the following problem:
I have a cuboid body having one inlet and one outlet. there are two liquid s in it with one layer of liquid over the other. So, how i will give the named selection and define them?
rkmittal1108@gmail.com is offline   Reply With Quote
Old   September 17, 2012, 01:01
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
In desginmodeler, when you select a body click on right button then "go to body".
The body will be selected in the right panel . look details box under you will that body is name solid, you can change that name or select if you want solid or fluid...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 17, 2012, 09:51
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, make it a fluid so it meshes as a fluid in ANSYS Meshing and gives you a fluid zone to work with in the solver,
but most of the setup for the dual fluid zone actually happens in the solver... (sorry, I don't recall the exact details myself).
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 18, 2012, 11:24
jsm
JSM
jsm is on a distinguished road
Hi Rohit,
If I understood your question correctly, you are asking about the named selection definition of one liquid and another liquid at inlet.
If it is your requirement, you can extend the cuboid length to long distance, then give the named selection by separating the inlet into exactly half or as like flow phenomenon. So when flow is coming in your area of interest, there won't be any effects of inlet partition for two liquids.
Let me know if it solves your problem.
With regards,
JSM
jsm is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Creating named selection for a line sketch amir00251 ANSYS 6 July 31, 2012 08:02
Named selection - design modeler jsm ANSYS Meshing & Geometry 0 November 19, 2009 07:44
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
