September 17, 2012, 13:13 |
Meshing Geometry
Evangelos
Hello!
i want to mesh the geometry in the picture parallel . I want to make boundary layer as dense as i can and the center of each volume thin. how can i do that ? i try to size every edge on my geometry but the results was not so good because there was skewness parallel 2 |
September 18, 2012, 07:56 |
Evangelos
today i try to mesh the geometry with sweep method and inflation.
How can i choose the common face between merged volumes ? |
September 18, 2012, 09:41 |
Ghazlani M. Ali
Rep Power: 28 |
i can't help you much with ansys meshing. everything i know so far is that, if your geometry is made of different parts, you have to select those part in ansys modeler, right click then "form new part", after that in ansys meshing, if you select update mesh, it will generate a random tri elemets. you probably know that...
You can select you bodies individually, right button, then insert method, when i mesh tubes, i usually select the multizone method, you can do that for those two tubes you have, after inserting the method, insert face mapped mesh, then select the round faces of the tubes, bottom and upper face. and in the general mesh parameter, insert inflation too. i hope this link will help: http://www.cfd-online.com/Forums/ans...s-meshing.html in another hand, this geometry is easy to block in ICEM CFD, i can help with it... |
September 18, 2012, 16:41 |
Ghazlani M. Ali
Rep Power: 28 |
if you wanna break the bodies into more pieces, you need to go back to ansys designmodeler and use the slice option in "create." you need to frozen you bodies so you can do that...
September 18, 2012, 16:59 |
Evangelos
Sorry i was not clear !
i want to make more domains on each side now i have 3 domains at x direction |
September 18, 2012, 17:19 |
Ghazlani M. Ali
Rep Power: 28 |
oh ok, now you go to mesh, click with right button, insert -» sizing, select that edge , then in details you can select number of division and give how many elements you want there
September 18, 2012, 18:18 |
Evangelos
thanks a lot!
[ICEM] Meshing an irregular geometry | Fabio Tabacow | ANSYS Meshing & Geometry | 6 | May 7, 2014 16:03 |
[ICEM] Geometry Meshing | protea | ANSYS Meshing & Geometry | 2 | November 22, 2011 12:15 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 13:12 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 02:13 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
