[ANSYS Meshing] Match Control on multi-body part |
August 14, 2012, 22:07 |
tl
Rep Power: 13 |
Hi everyone,
I am trying to apply periodic BC for both sides of this geometry. Thus, match control is required for both sides of this part. 1)The hex dominant(I would like to have hex mesh on piston bowl) method is used to piston bowl(bottom part) and the combination of mapped and sweep mesh is used to wall(upper part). But like what this picture shows, match control failed. 2) When I changed the mesh of piston bowl back to tet mesh, I got a wrong message I have never seen before. Any one knows reasons for this? What is the general way for multi-body part to create match control? Thanks in advance! Tianao http://postimage.org/image/qlidmgn39/full/ http://postimage.org/image/sd82vwcbj/full/ Last edited by tdbbz; August 14, 2012 at 22:27. |
September 19, 2012, 19:26 |
Dustin
Rep Power: 14 |
I know this post is a month old, but I was looking through ANSYS Meshing questions.
If your geometry is periodic and axi-symmetric within that periodicity, you should be able to apply cyclic symmetry instead of match control. Cyclic symmetry automatically enforces match controls |
September 19, 2012, 19:43 |
#3 | |
tl
Rep Power: 13 |
I have already got it solved. Thank you for your kind reply anyway! Tianao |
[ICEM] Meshing one body part only | serezhkin | ANSYS Meshing & Geometry | 3 | June 29, 2010 15:36 |
[GAMBIT] error:put mesh of ANSYS into GAMBIT | njiit | ANSYS Meshing & Geometry | 11 | December 16, 2009 20:00 |
application part of laminar newtonian fluid past bluff body | swamysrikanth | Main CFD Forum | 0 | December 15, 2009 01:53 |
Any other way of converting a multi part to a single part avoiding ANSYS Design Model | LusoMundo | ANSYS Meshing & Geometry | 1 | May 14, 2009 14:35 |
Coke Bottle | ram | Main CFD Forum | 13 | September 29, 2000 04:17 |
