[ICEM] Can I display the position of the minimum meshes? |
September 18, 2012, 15:55 |
I've just got a new geometry and blocking file and I want to know where the minimum volume mesh is. I want to make it a bit coarser as my computer can't supports such big mesh. When I check the block and want to show the min volume, it doesn't appear. Is there any way that I can get the position of the minimum meshes?
September 19, 2012, 08:01 |
#2 | |
Christoph
what exactely do you mean with minim mesh?! don't get your point
September 19, 2012, 09:26 |
September 19, 2012, 11:03 |
Christoph
sorry, but i really don't understand what you mean with "minimum mesh".....
please explain it to me. Do you want to coarsen the fine mesh? Or do you want to know your min. volume ratio? what exactely is the point?! |
September 19, 2012, 11:25 |
Simon Pereira
Rep Power: 47 |
Yes, there was a defect. When using the histogram for the volume metric, you should be able to click on any column and see the elements in that column displayed on the screen. However, some of the smaller volume columns were not displaying the elements as they should have. This defect has been fixed in 14.5, due out later this year.
In the mean time, I think that you could still display them by selecting the column and then right click to create a subset... Then you can display the subset.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
September 19, 2012, 11:31 |
Simon Pereira
Rep Power: 47 |
Here is a screen shot to illustrate that it is fixed in 14.5... It also shows the diangostic volume subset in the tree (create this with a right click on the histogram chart)...
September 19, 2012, 12:08 |
What I mean is explained by PSYMN, I just want to know where the smallest mesh is. Thank you for your help all the same.
September 19, 2012, 12:09 |
#8 | |
That's what I want, thank you very much.
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
how to read in a position file | jiejie | OpenFOAM | 0 | May 23, 2011 04:38 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Display Particle Position on a Plane | Jana | FLUENT | 2 | July 13, 2007 02:46 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
