[ICEM] Meshing strategy for 3D sharp point
Like Tree8Likes
Old   October 10, 2012, 22:55
Default Meshing strategy for 3D sharp point
Fan Derrick He
D-willism is on a distinguished road
Do you guys think this sharp point can be meshed well with hexa grids? any suggestions on the meshing strategy?
Looking forward to your replies, thank you!
D-willism is offline   Reply With Quote
Old   October 10, 2012, 23:03
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hmmm very difficult...
I once face a sharp geometry but not like this one. i had to use y-grid.
take a look at this video, there is no sound but i added annotations:
http://www.youtube.com/watch?v=nuiRkZqaEz4
try it with this method , come back to us here let us know how was it
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 10, 2012, 23:25
diamondx's Avatar
Ghazlani M. Ali
wait a second; y-grid needs to be applied to triangular shapes... yours is not...
just realized that while laying in my bed
May i ask what are you trying to model ?
Regards,
Ali
Old   October 11, 2012, 00:01
Fan Derrick He
Modelling? you mean CFD analysis? I am modelling the air flowing across this cone shape, so I have a cylinder enclosing the cone shape. but around the sharp point, the aspect ratio and skewness of the grids are kind of poor. Does this answer your doubt?
Old   October 11, 2012, 14:40
diamondx's Avatar
Ghazlani M. Ali
what software did you use to generate your mesh, can you post some screenshots ?
Regards,
Ali
Old   October 12, 2012, 01:04
david
davidwilcox is on a distinguished road
I once meshed a geometry with a sharp end. I used the quarter O grid blocking method for the sharp end. Maybe you can give that a go.
D-willism likes this.
davidwilcox is offline   Reply With Quote
Old   October 12, 2012, 07:44
Fan Derrick He
I am using ICEM CFD. Three pisc show the geometry, blocking and poor quality grids. all the poor quality grids gather around and are due to the wedge-like blocks at the right bottom of the rectangle geometry. If I can get rid of these two wedge-shape blocks which means only four blocks left around the half-cone shape, the quality of the grids should be very high. Any ideas or suggestions how to achieve this?
Best Regards
D-willism
Old   October 12, 2012, 07:45
Fan Derrick He
I will try that once I get to university tomorrow. thx
Old   October 12, 2012, 11:56
Far
Sijal
share geometry
Old   October 12, 2012, 20:42
Fan Derrick He
Originally Posted by Far View Post
share geometry
zip file includes 2 geometries I am trying now.
Best Regards
D-willism
Old   October 13, 2012, 03:43
Far
Sijal
For rectangular enclosure blocking is simple. Min quality is 0.9, however min angle is 16.9. Try solving this mesh in Fluent.
Circular Enclosure: The blocking of this geometry with circular enclosure is felt difficult to me always. Can someone guide us how to handle the circular domain in efficient way?
Old   October 13, 2012, 03:56
Far
Sijal
Please find enclosed files (.prj, .tin, .blk). After some adjustments in blocking min angle is greater than 18.
D-willism and Parsa.T. like this.
Old   October 13, 2012, 04:02
Far
Sijal
Best Regards
D-willism
The elements are prism and ICEM is very harsh on prisms quality (Simon told it in many posts, search you can find one). So give it try with your mesh also in solver and see what happens in terms of convergence with both meshes
Old   October 13, 2012, 04:27
Fan Derrick He
Thank you SO SO SO much! You've been very kind
Old   October 13, 2012, 05:43
Fan Derrick He
When I opened the project file using ICEM CFD 14.0, it required a attribute file? But obviously it is not in the file you posted, does it really matter? And hmm... because you adjusted the angle from 16 to 18, the min quality degrades and not the same as what you show us in the picture. Could you please post the files before you made angle adjustments please if you can? Thank you so much!!
Best Regards
D-willism
Old   October 13, 2012, 06:15
Far
Sijal
This file does not matter for the blocking. It has other functions.
In this mesh min quality is 0.8 and min angle is 18. Please uncheck the solid part if it is turned-on...
Old   October 13, 2012, 23:05
Fan Derrick He
Thank you Far! I am now trying to block and mesh the geometry without having those wedge-shape blocks at the bottom of the geometry, which means only four blocks left enclosing the semi-cone (solid, as you named in the file). Do you think it is feasible?
Best Regards
D-willism
Old   October 14, 2012, 01:45
Far
Sijal
I am sending you two project files (both include .prj, .blk and .tin). That is before merging the vertices and then after merging the appropriate vertices. Now you can apply the Y-block option on two wedge shapes blocks to get what I posted earlier.
PS. I have also used the build topology command to create the points at the required locations.
I have also used the ungroup curves command, available in blocking association panel
Old   October 14, 2012, 02:07
Far
Sijal
please see these five files, containing five steps from the creating the initial block to the final mesh. Quality is around 0.8 and min angle is 18
Old   October 14, 2012, 02:50
Fan Derrick He
Thank you Far! what I was trying to say is: do you reckon if it is feasible or possible to block the domain into four sub blocks, instead of including small wedge-like blocks as well underneath the sub blocks (big/major ones)?
Best Regards
D-willism
Meshing issue in sharp edges Moti Siemens 7 June 1, 2012 12:40
How to mesh the 1st grid point? Daniel Main CFD Forum 1 October 8, 2007 02:27
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
meshing a sharp edge line CFX 2 November 2, 2002 11:19
