[GAMBIT] How to convert a grid node to a vertex? |
October 11, 2012, 12:42 |
Mosi Owa
Hi
I have a complex geometry which has been generated by stereolithography (STL file). The thing is that the whole geometry is just one surface while I need to define some parts as inlet and outlet. What I have in my mind is to put some vertices on those related faces of my interest and create a plane (or face) and then move on toward the rest of it; but the problem is that I don't know the right coordination to put the vertices. I have meshed my surface and am sure that my face of interest (shown with a green circle and arrow in the attached image) is completely planar and I could tangent a surface on it but I do not know how! Does anyone have an idea? Thanks Last edited by BMCombustor; October 11, 2012 at 14:56. |
October 12, 2012, 00:59 |
Maxime Perelli
Rep Power: 41 |
the question is: is your volume virtual or real?
Because the handling may be quite laborious with virtual, but you can try this: If you want to add your circle as imprinted circle on your surface mesh, then create your circle away (and normal) to your surface, and finally try to project your circle on your surface by enabling split option, and giving the right vector (that's why I mentionned "normal" earlier). http://aerojet.engr.ucdavis.edu/gamb...create_project
In memory of my friend Hervé: CFD engineer & freerider |
October 12, 2012, 14:04 |
#3 | |
Mosi Owa
Thanks |
October 15, 2012, 01:30 |
Maxime Perelli
Rep Power: 41 |
Can you provide me your dbs file?
October 15, 2012, 14:06 |
Mosi Owa
October 24, 2012, 06:59 |
Maxime Perelli
Rep Power: 41 |
edge projection doesn't work properly and you can do something by projecting parts of edges (circle).
Maybe you need to work on the stl file with a cad package and then reimport in Gambit Sans titre1.jpg Sans titre2.png
October 25, 2012, 11:00 |
#7 | |
Mosi Owa
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
convert a structured multiblock grid to an one unstructured: modification of cells | Mirage | ANSYS | 0 | July 18, 2012 09:14 |
[ICEM] convert a structured multiblock grid to an one unstructured | Mirage | ANSYS Meshing & Geometry | 4 | July 11, 2012 10:36 |
CGNS - convert BC from node to face | Charles | Main CFD Forum | 1 | November 1, 2008 08:50 |
How to convert cgns filr in node array? | John | FLUENT | 0 | November 12, 2006 22:54 |
