[ICEM] Importing using IGES file format
Like Tree1Likes
  • 1 Post By diamondx
Old   October 30, 2012, 15:27
Default Importing using IGES file format
Ugly Kid Joe
vmlxb6 is on a distinguished road
Hello all,
I am trying to mesh a muffler assembly of an engine. when I import the entire assembly into ICEM using the IGES file format, all the surfaces are combined under a single name. It becomes extremely tedious to clean up the geometry because of the number of planes and bolts and washers not needed for fluid flow analysis.
I would like to know if there is a way to import it in multiple parts instead of all the surfaces under a single name, so that when i am working on one part I can switch the others off. This would greatly help me reduce my time and effort.
I tried to create IGES for individual parts and then import in ICEM but they do not fit in their respective places. Any kind of help or suggestion is greatly appreciated.
Thank you very much.
vmlxb6
vmlxb6 is offline   Reply With Quote
Old   October 30, 2012, 16:03
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
just different part in icem so you can switch between them.
when i work with designmodeler, i name those part there, i export my geometry using agdb file format. then i use workbench reader in icem to import it. the importation is done with all the name given in designmodeler so i don't need to create parts.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 31, 2012, 08:40
Default @ diamondx
Ugly Kid Joe
Thank you for your reply. I have the current assembly model in Pro/E and when I go to export it I do not find any agdb file format.
Also I am using the ICEM stand alone without the use of workbench.
Let me know if there is something else I could do. Thank you very much.
Old   October 31, 2012, 09:14
diamondx's Avatar
Ghazlani M. Ali
agdb is a ansys designmodeler extension. you only find it in designmodeler, if you are using pro/e try exporting in step. that's the format i use. may be someone else can give another option...
Regards,
Ali
Old   October 31, 2012, 20:24
PSYMN's Avatar
Simon Pereira
yea, it depends how you create the IGES file. if it is created with separate parts, etc. then you will get separate parts in ICEM CFD... If not, then not.
Do you have access to the Pro-E interface with ICEM CFD? That is the best way to bring parts across (IGES is one of the worst ways), and they will come with all their original ProE part names.
If not, then there are tricks you can use to help you select entities in ICEM CFD more efficiently.
CFD Online Users Survey
Old   November 1, 2012, 12:36
Default @ simon
Ugly Kid Joe
I tried to make individual IGES files for each and every part of the assembly and then import them one by one. The problem is that when i go to merge them they all get located at one single place. this method does not respect the assembly positions.
Also I do not have pro/e interface with ICEM CFD. Is there any other way i can solve this issue of mine ? thank you very much.
any tricks or suggestions will be appreciated. Thanks.
Old   November 1, 2012, 12:43
diamondx's Avatar
Ghazlani M. Ali
it's weird i already worked with assembly in pro/e, but instead of importing it in icem directly, i was passing by DM. step file works great, also when exporting i select solid and shell... can you make a stop first by Designmodler see how it looks there and then load it in icem ...
PSYMN likes this.
Regards,
Ali
Old   November 1, 2012, 12:44
diamondx's Avatar
Ghazlani M. Ali
share some pictures of your assembly if you can...
Regards,
Ali
Old   November 2, 2012, 09:48
Default @ DiamondX
Ugly Kid Joe
I do not have DM in my system and I doubt if the IT will ever install it for me since 99% of the employees use pro/E.
People who do analysis here at my company use hypermesh and I am the only person who is using ICEM, and i do not want to go with the herd. hopefully there is a better way out of this situation else i will have to learn hypermesh. and am not very keen on doing that.
thank you very much for your response.
Old   November 6, 2012, 17:33
Yon Han Chong
yonchong is on a distinguished road
I use Parasolid Format for import into ICEM. You might try it to see whether your assembly is read in with different part names.
yonchong is offline   Reply With Quote
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
