[GAMBIT] Boundary layer direction
Old   November 7, 2012, 08:39
Default Boundary layer direction
Markus is on a distinguished road
I have a very frustrating problem and i read through so many posts but nothing works.
I have substracted my cubic like geometry from a big cube for the computational domain and now want to create a boundary layer on the inner surface of course pointing to the fluid. But gambit always points it inside ?!?!!
I have read about using the middle button of the mouse, double left klick and to use the list and add the same face until it points the right way.
But it just doesn't work.. :-(
Also i tried defining the space in between as fluid and the structure as solid..
I would appreciate any type of help a lot! Pleeease help me!
Thanks!
Markus is offline   Reply With Quote
Old   November 8, 2012, 04:43
Marion
Marion is on a distinguished road
Hi Markus,
Do you have volumes other than your fluid domain in Gambit?
Can you add a picture, it would be easier to understand...
Marion.
Marion is offline   Reply With Quote
Old   November 8, 2012, 06:54
Hi Marion,
Thank you for answering. I think i only have the fluid volumes. (see pictures 3 and 4)
The geometry in the middle is the thing i want to put in the flow. then thought its good to make a close region for the boundary layer and a fine mesh and then i wanted to fill the rest of the computational domain (volume2) using a size function.
best,
Markus
Old   November 8, 2012, 08:32
Tamil Nadu
nkme2007 is on a distinguished road
Hi Markus,
Mine is also similar problem, I feel. I want to model a building in GAMBIT 3D. Finally, aim of my project is to simulate the temperatures of the walls of building when water flows through pipes inserted in the ceiling (using Ansys Fluent). Is it possible to solve??
nkme2007 is offline   Reply With Quote
Old   November 8, 2012, 10:12
Marion
Originally Posted by Markus View Post
Hi Marion,
best,
Markus
Markus,
Try to split your volumes first, it will be easier to control the mesh.
Is it hollow in the middle? or do you still have a volume there?
If you want, you can attach your model and I'll have a try.
Marion.
Old   November 8, 2012, 10:24
i think it is hollow... :-)
That would be very nice of you, thanks!
Markus
Old   November 9, 2012, 03:17
Marion
I've just had a look, and I got the same issue on your original model.
But I confirm my advice: split your volume into smaller domains.
I split it in 8, and I used BL on edges it worked very well
As it is a simple geometry, you can even split it on each side of your small parallelepipeds.
I hope this helps,
Marion.
Old   November 9, 2012, 03:18
Marion
Originally Posted by Marion View Post
I hope this helps,
Marion.
Here are some snapshots.
Old   November 9, 2012, 03:53
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
boudary layer is good option, but should be used where it is appliable. Dividing into small volume is the best approach for hexa mshing and mesh control in particular area. For example see this thread http://www.cfd-online.com/Forums/ans...d-channel.html and this video: http://www.youtube.com/watch?v=Gub1Kbcup2k&feature=plcp
Far is offline   Reply With Quote
Old   November 9, 2012, 04:38
Far
Sijal
How many cubes are there? do you want to mesh inside the small cube, where small sheets are present? Is it part of Fluid?
Do you have access to ICEM?
Old   November 9, 2012, 11:14
hi
Thank you very much for all the advice, i will try it out.
Markus
Old   November 9, 2012, 12:10
Far
Sijal
There are three cubes and some protrusion (six in total)? volume inside the small cube (cube) is hollow? and also volume inside six small box is also hollow?
Old   November 9, 2012, 13:09
The geometry which represents the solid is the big cube and the six cubes on the surfaces, they are not fluid.
Its a model of a cubesat with thrusters (6 small cubes ) for an underwater test.
I did try by splitting, but it also looks strange now
Old   November 9, 2012, 13:22
Far
Sijal
like this.....
Old   November 12, 2012, 05:01
Far
Sijal
I hope this is helpful to you.
direction of boundary layer in gambit Ilu FLUENT 8 August 27, 2018 17:38
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
simulation of stokes boundary layerr (oscillating boundary layer) beguxa FLUENT 1 December 10, 2011 04:30
Help!!!: Direction / Normal of Boundary Layer JP FLUENT 0 September 9, 2008 18:16
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
