November 9, 2012, 08:55 |
Volume Orientation Problem
Kentin cal
Hello everybody!
Here is my problem : pier.jpg As you can see on this picture, it shows a draft tube pier. I use o-grid and an hexa meshing. After an ICEM checkMesh, it informs me that negative volume are present on this part. I tried many stuff to fix the problem but it unfortunately did not come off. I wil be very glad to have some help, Kentin |
November 9, 2012, 10:32 |
Kentin cal
Negative volumes are defined when i do a Blocking->Pre-Mesh Quality (criterion determinant 3*3) between -1;1.
I find volumes below 0 with this criteria, concentrated on pier nose (see picture in my first post). Once again, i find these volumes when i do a checkMesh with option createSubset. I Volume Orientation Subset is created and means that i have an error here. I tried to unrefine mesh and other things but i did not find solutions to solve this volume orientation problem. If you have any idea... Thanks a lot, Kentin |
November 9, 2012, 17:45 |
Ghazlani M. Ali
Rep Power: 28 |
make sure edge bunching law all same for all parallel edges.
Use scan edge to see where does the problem come. You may share your project, i can take a look at it... |
November 12, 2012, 09:53 |
Kentin cal
I checked all parallel edges and did not find anything special.
Same thing for scan planes, actually first picture i posted came from a scan. And as you can see, there is no special thing visible.. If you have any others ideas to check meshing, i ll be very glad to hear it! Quentin |
November 13, 2012, 05:01 |
aysiyi
in my mind, if you have some negative volumes, maybe you have some problem association ,you shoud see the edge association
November 13, 2012, 12:09 |
Kentin cal
Thanks but i finally found the solution.
In blocking->check Blocks->Fix Inverted Blocks, very usefull tool! No negative volume anymore. Thanks for all your advices. Kentin |
November 13, 2012, 12:31 |
November 14, 2012, 03:01 |
Kentin cal
Negative orientation is not negative quality but negative volume specified by 3*3 determinant quality.
I found the solution thanks to this post : http://www.cfd-online.com/Forums/cfx...-icem-cfd.html I just used the tool i notice in my last post.. |
icem volume orientation |
volume fraction problem | naor | FLUENT | 1 | March 29, 2012 11:54 |
[blockMesh] Problem with Mesh Volume | seboxx | OpenFOAM Meshing & Mesh Conversion | 3 | January 30, 2012 08:19 |
Problem of negative volume.......Please help | nims | FLUENT | 3 | November 2, 2010 02:07 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
volume mesh problem | Christophe | FLUENT | 10 | June 8, 2006 02:53 |
