[ANSYS Meshing] problem about flowPath feature in bladEditor |
November 11, 2012, 04:19 |
aysiyi
hi
guys, I have made my centrifugal impeller model in solidworks ,but it is so hard to mesh it in ICEM CFD,so i choose to mesh it in turbogird,in order to export the impeller geometry to turgird, I use the bladEditor in ansys design modeler. first ,i have to use the flowPath feature to create(specify) the flow path, I'm sure about the inlet/outlet/hub/shroud contour,but how can I decide the layer contour ? for example, how many layers contours? the shape of the layer contour ? thanks |
November 13, 2012, 06:29 |
aysiyi
it is not a tutorial in the help documents, and i have solve the problem ,just right click on the layer hub or shroud to choose add a lower(upper) layer,then the bladeditor will add layers automatically. thank for reply
January 21, 2014, 11:33 |
lauda
Rep Power: 12 |
I'm trying to export a geometry file of a single radial blade passage (i have inlet, outlet, periodic, hub and shroud surfaces) to turbogrid. However I'm not able to specify the flow path. For instance I click on hub contour but there is no way that i can highlight the surface and select apply. What does hub contour stand for? surface or curve/line? Thanks in advance, sorry I'm new to ANSYS and I really need to generate the mesh with turobgrid rather than with ICEM.. |
bladeditor, layer contour, turbogrid |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
