November 20, 2012, 03:42 |
Blocking strategy ICEM
Marijo
Is this a good blocking strategy? Thanks! |
November 20, 2012, 04:36 |
AB
Rep Power: 21 |
It looks like, but maybe you should give more information :
why do you think it would not be a good strategy ? have you experienced some issues with your mesh ? Quality is not good ? |
November 20, 2012, 05:15 |
Marijo
Hi Alexandre,
Thanks for your answer. I am worried about the aspect ratio and angle of the cells as I change the angle of the geometry (inclination of the plates). It is shown in the pic below. |
November 20, 2012, 10:11 |
Ghazlani M. Ali
Rep Power: 28 |
i understand why you're worried. this thread will help you solve the problem:
http://www.cfd-online.com/Forums/ans...ic-trough.html |
November 21, 2012, 05:14 |
#5 | |
Li
November 21, 2012, 08:52 |
#6 | |
Philipp
Rep Power: 26 |
Unfortunately, if you guide the grid around such a corner, the angel between the to adjacend edges is allways 270°. Thus, the two cells have the problem: if you improve one of them, the other one gets worse. Anyway, if you don't guide the grid around the corner, your wall cell refinement will "radiate" (however you call that in english) into your whole domain. In both cases you are doomed. The bad aspect ratio can be avoided by refinements, but again you get these "beams" of refinement into your whole domain. Also: In your picture, inside the red circles, You have points where 5 edges meet. In my view, it is generally better if the angels between them have equal sizes, i.e. you split the 360° into equal parts... |
November 21, 2012, 10:44 |
#7 | |
Ghazlani M. Ali
Rep Power: 28 |
Can you post some details about your geometry (pics, project ...) |
November 22, 2012, 01:14 |
As I can see from the image angle is around 45 degs for each inclined plat. So the best approach would be making the simple topology and two splits at the front and rear. In this way you can avoid the steep angle as shown in following images.
November 23, 2012, 05:49 |
#10 | |
Li
http://www.cfd-online.com/Forums/ans...-geometry.html |
Helical wire wrapped around cylinder blocking strategy in ICEM | wingcollide | Main CFD Forum | 6 | December 25, 2013 19:32 |
[ICEM] o grid blocking strategy? | icemaniac178 | ANSYS Meshing & Geometry | 14 | March 19, 2013 23:18 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Using Blocking with ICEM (infinity lines appear) | Touré | ANSYS Meshing & Geometry | 6 | August 5, 2012 17:07 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
