[ANSYS Meshing] ANSYS meshing for CHT problem
Old   November 23, 2012, 13:00
Default ANSYS meshing for CHT problem
Sandeep
sandy_1982 is on a distinguished road
Hi friends,
i need to do an aircraft engine bay ventilation study and i have the following :
1 . aircraft skin of 1 mm thickness , and engine sits inside whose temperature on the surface is known
2 . surrounding fluid domain (air)
I am meshing both the solid and the fluid domain.
I am going for a hexa mesh with three cells across the 1mm thickness of the skin by making it sweepable by slicing operations
My queries are :
1. what is better : a tet mesh or a hexa mesh for the solid domain ?
2. i am planning for a tet mesh for the fluid domain and an inflation layer over the skin , is this approach of meshing good - looking at the overall objective of obtaining the temperature distribution both in the solid (skin) domain and the air surrounding it.
Thanks & regards
Sandeep
sandy_1982 is offline   Reply With Quote
2d meshing in ansys meshing syler3321 ANSYS Meshing & Geometry 10 November 1, 2012 20:42
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 09:48
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 12:09
