[DesignModeler] Script function to pick single Solid Body |
July 25, 2015, 19:18 |
Eduardo Firvida
Rep Power: 15 |
Hi I need to select a solid body Design Modeler with script, in a design with multiples solids bodies. with the following command I select all the solid bodies but this is not what I need. I need to select one of all
ag.bodyPick; ag.gui.SelectAll(); |
July 26, 2015, 18:44 |
Rep Power: 14 |
Hi efirvida,
You have to first named select the body ( namsel1) you want to pick then use below code where you want to select that body Code:
ag.bodyPick; agb.AddSelect(agc.TypeBody, namsel1); Cheers KAPI |
scripting, scripts |
moving a cold solid body into stationary hot air for heat transfer | shyamgarg | Main CFD Forum | 3 | December 26, 2019 22:41 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[DesignModeler] how to subtract a surface body from a solid body? | yahya | ANSYS Meshing & Geometry | 4 | January 7, 2013 11:00 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
