January 5, 2013, 13:12 |
blocking splined curve pipe
jyh
Rep Power: 13 |
Hi all
Recently I'm exercising ICEM Tutorial. Suddenly, I'm interested in blocking strategy for splined curve(not bendng pipe of 90 degree) pipe like a picture I added. I have a no idea that sigle block is not appropriate to this problem. I should split block, but I don't know how to split because this geometry seems to need a zigzag blocks(?) help me ~ |
January 6, 2013, 01:36 |
No problem. You don't need the zigzag blocks.
But you must understand the basic working of ICEM. ICEM by default project the faces to the nearest surface (and you only do the vertex and edge association). Your problem is both sides (360 I should say) are projecting to the one side of the pipe. So either make the more splits so that straight edges of blocking resemble the curved geometry or use the edge command (spline or linear) to make the edges conform to geometry. Got it? Last but not the least : Make the four curves on the surface of pipe at interval of 0, 0.25, 0.50 amd 0.75 to control the blocking. But this is not necessary. |
January 6, 2013, 05:27 |
Thanks Far!!
jyh
Rep Power: 13 |
Oh, I've done it! thank you so much.
Your last mention was very helpful for me. (make curves along geometry at 0,90,180,360 degree) and I moved vortexes to projected points, it works! Anyway, now.. how to export mesh file for Fluent? because of VORFN, SOLID parts, I can't apply B.C to them. also delete them. if I remained them, I think they'll make error in Fluent. What can i do? |
January 6, 2013, 07:31 |
Also make one ogrid to improve the quality.
Go to output tab and do following steps 1. Right click on the premesh and select option unstructured mesh. 2. Select solver Ansys Fluent (1st tab) 3. Boundary conditions (2nd tab) on inlet, outlet and wall. Make sure you have defined the parts (surfaces) for them. 4. output mesh (last tab) Before that you should move all points to new part (name is points or any thing else as you like) and all curves to new part and then apply boundary condition on surfaces as mentioned in step 2 above. Last edited by Far; January 6, 2013 at 14:20. |
January 6, 2013, 09:58 |
Apply B.C to solid part
jyh
Rep Power: 13 |
oh, I've done calculation. Thank you sosososo much~
SOLID part made a problem in setting B.C, but I could fix it by setting the part for 'fluid' B.C Regards&Thanks |
January 6, 2013, 10:41 |
Are you interested in solid part ?
I guess you have chosen the default option for the blocking. Rename it to Fluid and don't specify boundary condition for it. If there were any solid (which is not here) and you dont want to import it in the mesh then simply turn it off before making the unstructured mesh and export mesh. |
January 6, 2013, 11:37 |
blocking in fluid part?
jyh
Rep Power: 13 |
you sound like that it is allowed to create block in 'fluid part' which has body. right?
I used to do that, but.. most of you look like to work blocking with 'SOLID part'. so I did like them. I'm confused. Which one is general? |
January 6, 2013, 13:13 |
#9 |
jyh
Rep Power: 13 |
Oh I see... now I understand the basic idea of Hexa meshing.
Thank you very much Regards |
Display Modes | |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 23:14 |
[ICEM] Blocking topology for pipe flow with a butterfly valve | siw | ANSYS Meshing & Geometry | 13 | November 27, 2012 13:07 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
