[ICEM] Negative volumes
Old   January 26, 2013, 05:23
Question Negative volumes
Francisco
Bollonga is on a distinguished road
Hi everybody,
I'm working on a 3D geometry of an inclined flat plate. I'm doing a hexa mesh as it is a rather simple topology. Before converting it into unstructured mesh (to export it to Fluent) I check it and fix the problems, then I smooth (with smooth for hex/orth mesh tool) it for 10 iterations, including the volume orientations option. I also make the first layer to be 1e-5 to have a low y+.
The problem is that Fluent says there are negative volumes, and I can't fix it with Icem tools.
How can I solve that?
Any suggestions are welcome! Thanks!
Bollonga is offline   Reply With Quote
Old   January 26, 2013, 06:11
Francisco
This is the message that always appears when I try to fix or to smooth the mesh:
Running diagnostics for Volume orientations in subset "all"
52 problems were found for Volume orientations
52 elements could not be fixed -- probably the element quality is too bad.
Old   January 26, 2013, 07:07
Francisco
I've ploted the negative volume elements, they are all in two blocks. I've redone the edge and vertex associations and remeshed, nothing changed.
I've tried to invert blocks orientations, and nothing has changed.
What else can I try? Please help.
Old   January 26, 2013, 08:28
Daniel Ceglarski
Daniel C is on a distinguished road
I am currently running into the same problem. I assume it is caused by the geometry. Have you loaded a step file? You could check if the coordinates off all points are properly aligned.
Just a thought.
Daniel C is offline   Reply With Quote
Old   January 27, 2013, 05:54
Francisco
Just a thought.
I've just made all the geometry as it is rather simple. I'm trying now to improve the quality cause I haven't noticed before the Quality menu in the blocking tab. It's giving error messages like the one in the image.
I guess I have to improve the quality, but this messages doesn't allow me to proceed!
Old   January 27, 2013, 06:09
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Hi.
There must some basic mistake. Smoothing will not help in this case...
Far is offline   Reply With Quote
Old   January 27, 2013, 06:26
Francisco
I have many negative 3x3 determinants, I don't know what that means, but I'm trying fixing it with the quality up to -0.7 which is the minimum value reached. If I put a positive value, i.e. 0.2, the former message appears. I'm waiting for the results now, I'll let you know.
Old   January 27, 2013, 06:41
Far
Sijal
There are many reasons like you had in previous posts. Or it may be due to block orientation and can be rectified through tools in blocking tab or edit mesh tab.
Few pics or icem files would be necessary to comment further.
Old   January 27, 2013, 08:16
Francisco
Hi Far,
Here you are my icem files. I haven't uploaded the .uns files cause they're pretty big.
I have similar problems with a bigger mesh (1.8Gb) so I'd like to know the process to fix it.
Thanks!
Old   January 27, 2013, 08:27
Far
Sijal
Same problem so same solution. Please refer to your own thread and read Post # 16.
Post # 16 By Simon
http://www.cfd-online.com/Forums/ans...em-fluent.html
Old   January 28, 2013, 07:20
Francisco
I've redone all the blocking again until I got no negative 3x3x3 determinant. I don't know why I can never execute the pre-mesh quality tool. All the same I's smooth it 20 iterations and exported it to fluent. I all seems to go okay but fluent says there are some left-handed and right-handed faces. I'm already running the simulation but I would like to know what that means and how to fix it.
I've searched this thread but I didn't get much useful info.
http://www.cfd-online.com/Forums/flu...nded-face.html
Thanks!
Old   January 28, 2013, 08:03
Alexander
Pospelov is on a distinguished road
Hello.
You have missed the surface.
Pospelov is offline   Reply With Quote
Old   January 28, 2013, 08:36
Francisco
Originally Posted by Pospelov View Post
Hello.
Thanks, I already corrected that.
Old   January 28, 2013, 09:29
Far
Sijal
I think it is very simple case for ICEM. I also see many curves and points which are really not required in ICEM except they are made for some special purpose and in fact it is the hidden power of ICEM.
Old   January 28, 2013, 10:25
Alexander
And you should create O block like this. ))))
Old   January 28, 2013, 10:31
Francisco
Thanks Far, my blocking is still running without any problem. It is very similar to the one you made for me. I'll let you know the results.
Old   January 28, 2013, 10:37
Francisco
Thanks a lot Pospelov! You have used the o-grid block option in the blocking tab, right? I also use to force some 1st layer thickness at the smoothing stage.
Old   January 28, 2013, 10:43
Alexander
Yes. I used it there.
Old   January 28, 2013, 10:44
Far
Sijal
Yes O-grid will make the solution more accurate
Old   January 28, 2013, 17:44
Francisco
How have you made this O-grid exactly? from block? from faces? Edges? vertices?
Thanks
flat plate, hexa mesh, icem, negative volumes
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
