[DesignModeler] Diffuser geometry
Old   January 31, 2013, 18:47
Default Diffuser geometry
victoryv is on a distinguished road
Can someone tell me how to draw this in design modeler? I have dimensions of starting and ending square. I tried using loft but it ended up having straight edges rather than curved one.
victoryv is offline   Reply With Quote
Old   January 31, 2013, 19:24
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Can't you draw sketch the profil in red and extrude ??? that's how i would have done it
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 31, 2013, 19:39
The problem is it is diverging in both the directions.I also tried loft after measuring from the model and drawing intermediate squares between first and last squares . But it is giving me errors.
Old   January 31, 2013, 20:25
After spending lot of time I came to know how to do this. Draw the 3d curve connecting corner points (starting square to final square through intermediate squares ) . Create surfaces from edges and sew them together to form a solid.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 26, 2011 23:25
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 11:02
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 19:51
urgent help! car geometry Arjun FLUENT 0 August 13, 2007 13:07
