[DesignModeler] Freeze/Unfreeze and Enclosure options |
February 1, 2013, 12:08 |
I am a beginner with ansys 14.5 and would like to import some models from Pro Engineer. And I have these questions: 1.- The model consists of many body that are imported as freezed bodies. They are represented as ice cubes. How does affect this the model in Mechanical? 2.- I am experiencing problems with some of this imported bodies. Is there a way to deactivate (or erase them) from Design Modeler without having to create models without this bodies in ProEngineer? 3.- Error when I generate WITH THE ENCLOSURE: Conversion of body to DesignModeler format failed. How could I know why and what should I do? Thanks in advance. Last edited by HMN; February 1, 2013 at 12:30. |
February 4, 2013, 07:24 |
I found that there're very small overlaped areas between the parts. And when I import only one part there's no errors creating the enclusure.
Are there options in Ansys (Design Modeler) to repair these problems and remove these overlaped areas from the geometry? Thank you |
February 7, 2013, 07:00 |
At the end I found the solution of this problems by exporting from ProE with STEP format. Then I imported with SpaceClaim and prepared the structure and used the Prepare> Ansys button to export. And everything worked fine.
[ANSYS Meshing] Meshing of a 3d Ringwing in a cylindrical enclosure | Lukas_ZH | ANSYS Meshing & Geometry | 5 | March 14, 2015 05:49 |
[DesignModeler] Sweeping or surface meshing in enclosure? | Edu-R | ANSYS Meshing & Geometry | 9 | January 23, 2013 13:41 |
[DesignModeler] Negative value for Enclosure Cushion | siw | ANSYS Meshing & Geometry | 1 | November 1, 2012 11:44 |
radiation inside an enclosure | sagila | FLUENT | 1 | October 31, 2012 02:54 |
[Other] Problematic Geometry- meshing with enclosure. | lev1athan | ANSYS Meshing & Geometry | 2 | February 24, 2012 16:24 |
