[ICEM] How to export Icem mesh to Cfx?
Like Tree6Likes
  • 1 Post By flotus1
  • 2 Post By darazsbence
  • 1 Post By jrunsten
  • 1 Post By Far
  • 1 Post By Far
Old   February 21, 2013, 17:11
Default How to export Icem mesh to Cfx?
Darázs Bence
darazsbence is on a distinguished road
Hi everyone!
My problem is quite simple but i'm new to Icem so i have difficulties only. Anyway, i created a 2d mesh in Icem and i want to use it Cfx but i cannot manage to output it.
I always get an error messege that says: "no volume elements found.child process exited abnormally".
I tried to extrude the mesh by one layer only as my simulation would be 2D but i got the same error again.
Thanks in advance
darazsbence is offline   Reply With Quote
Old   February 21, 2013, 20:23
mjgraf is on a distinguished road
CFX requires 3 elements thick i believe
search the forum there is a description and I also think a tip about export to fluent, importing that into Pre and it does it automatically?????
Originally Posted by darazsbence View Post
Hi everyone!
Thanks in advance
mjgraf is offline   Reply With Quote
Old   February 22, 2013, 04:06
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Ansys CFX has no 2D Solver. Fluent on the other hand does...
CFX requires a volume mesh with at least ONE cell in the direction of symmetry. ICEM can extrude your 2D mesh to 3D.
chaitanyaarige likes this.
flotus1 is offline   Reply With Quote
Old   February 22, 2013, 07:25
Darázs Bence
First, thank you guys for the quick answers, i really do appreciate them.
Unfortunatly, i have to use cfx for solving my assignement, fluent is not good for me. The other thing: how to create a 3d mesh from a 2d mesh? I created a 2d geometry then the blocks and the mesh, all this in 2d. After this, a selected extrude mesh and extruded it. I thought this would result in a volume mesh but as it apperas it wouldn't. Please help me out. Thank you again.
chaitanyaarige and Mfaizan like this.
Old   February 22, 2013, 07:30
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
You can export a 2d mesh to fluent format (msh). When imported to cfx it will automatically extrude it one element for you
jrunsten is offline   Reply With Quote
Old   February 22, 2013, 08:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Export as .msh (Fluent mesh) and import into CFX-Pre. You will get the mesh one element extruded by CFX for you.
Or you can extrude mesh in edit mesh tab. Convert pre-mesh to unstructured mesh and use edit mesh tab.
Far is offline   Reply With Quote
Old   February 22, 2013, 09:16
Darázs Bence
I got it working, thanks everyone.
Another problem came up: when i imported the cfx5 file into cfx-pre and i tried to determine boundary conditions i cannot select any of the surfaces, i only have one thing to choose, it's called: Primitive 2d. Is it possible that in icem i somehow create surfaces that actually appear in cfx-pre and i can select them as inlet, outlet, wall etc. ?
Huge thanks to every one of you.
Old   February 22, 2013, 09:53
Far
Sijal
You should be able to select the boundaries in CFX-Pre. I guess it is not possible to export boundary conditions from ICEM to CFX.
Old   February 22, 2013, 10:50
Darázs Bence
When i create the cfx5 file i got this messege in the log:
"WARNING : family SOLID has mixed of 2D and 3D elements, this is not allowed in CFX-5.". Do you have any idea what problem can it cause and how can i help it? Thank you.
Old   February 22, 2013, 11:22
Far
Sijal
re-name solid to Fluid and try...
Old   February 22, 2013, 12:10
Darázs Bence
Doesn't work.
I also tried something else:
I started cfx from workbench and created the geometry in mechanical. After that i started meshing and inserted mesh method then selected uniform quad, and switched write icem cfd file to interactive. After all of this i created the mesh in icem and converted pre-mesh to unstructured mesh at the end. Even so when i close icem, in workbench meshing i'm stuck with the old mesh. How can i preserve the mesh i created in icem?
I really don't know what to do.
Thank you.
Old   February 23, 2013, 14:09
flotus1's Avatar
Alex
Sounds like you need to delete the remaining 2D mesh...
cfx, icem, mesh, output
ICEM export mesh Youen ANSYS Meshing & Geometry 34 April 23, 2017 12:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] export structured mesh from icem to fluent alecon88 ANSYS Meshing & Geometry 4 January 23, 2012 17:53
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
