[ICEM] Changing rotation axis
Old   April 9, 2013, 09:29
Default Changing rotation axis
Rolando Figueiredo
RPFigueiredo is on a distinguished road
Hello again,
Although I have suffered a bit, I've managed to create a reasonable mesh for a rotor-stator system on ICEM. However, when I came to perform the computation on CFX, I realize that perhaps it is necessary that the mesh be properly aligned with the correspondent axis of rotation on ICEM.
As you can see in the images, I would like to realign the whole mesh so that its centre is actually the curve I drew through the points 0,0,0 and 0,100,0 (ie. y axis).
Also, since this mesh only shows the rotor, I would like to know how to achieve the same re-positioning with the stator so that they end up properly aligned (ie match two corners of each mesh to the exact same location, perhaps).
Thank you in advance!
RPFigueiredo is offline   Reply With Quote
Old   April 9, 2013, 10:41
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i'm not sure of what you want to do. but i know how. you'll find happiness under the edit mesh tab -» transform mesh...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 10, 2013, 10:53
Rolando Figueiredo
Yeah, you got it!
Thanks a lot!
OF 1.6 extend. GGI - rotation around two axis - C++ newbie needs help A.Wendy OpenFOAM Running, Solving & CFD 1 February 4, 2013 08:05
Change axis rotation of MRFZone trantoan2008 OpenFOAM 5 November 17, 2011 09:37
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 11:05
Relief Plots in CFX Michael CFX 15 June 30, 2006 08:01
Axis of rotation Dunga CFX 4 May 11, 2003 10:44
