November 3, 2009, 03:32 |
Drawing Semi Cylinder
Sherif
Rep Power: 17 |
since i am not very familiar with gambit i have a question that is very easy i think but i cant do it
how to draw a semi cylinder in Gambit ? Thank you |
November 3, 2009, 06:18 |
Maxime Perelli
Rep Power: 41 |
different ways:
* create an arc-circle with 180° * create a full-circle and create and straight edge --> split cercle with edge
In memory of my friend Hervé: CFD engineer & freerider |
November 3, 2009, 08:11 |
Sherif
Rep Power: 17 |
thank you but then how should i extrude it to make it 3d Cyliner (pipeline)
November 3, 2009, 09:41 |
Maxime Perelli
Rep Power: 41 |
once you have your semi-circle, close it with a straight edge.
Create the surface and then create volume (sweep faces)
July 26, 2014, 16:01 |
Draw semi Cylindrical wire
forough
Display Modes | |
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 09:59 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 10, 2008 00:02 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 19:40 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 06:32 |
