[ANSYS Meshing] Solid inside Fluid - Multizone meshing
Old   March 8, 2013, 20:04
Default Solid inside Fluid - Multizone meshing
Matteo Colli
supercolli is on a distinguished road
I am an Ansys Meshing beginner, so I ask for a little help.
I want to obtain a structured grid, at least in the vicinity of the boundary walls, for a problem constituted by a large box of fluid and a void completely inside him (cilindric). I obtained the fluid geometry by means of a boolean subtraction in the DM sofwtare and the void geometry by non preserving the tool body. It's the case reported in this image.
Uploaded with ImageShack.us
The boundary wall in my intention are the ground (the base of the big fluid domain) and the walls of the void shape.
As shown in the figure, the internal void shape can be considered as a vase which is here modeled without the solid part, so there is a zone of fluid contained inside the vase while the major fluid domain resides in the external part of the vase.
The problem is that if I select the fluid body and insert in a Multizone method with Hexa "mapped mesh type" and a not allowed "free mesh type" the resulting mesh doesn't make is very coarse in the fluid domain, with very large grids on the domain surfaces. So I tried to specified an Inflation boundary on the base of the larger box (representing the ground) and on the walls of the void but here I got a new problem. How can I select the void surfaces for the inflaction specification if they are completely immersed in the fluid?
I know that this would be an easy task for most of you so please give me some suggestion about how to obtain a good grid for the fluid domain with structured mesh at least around the solid and the ground boundary. This is necessary for the application of a LES simulation.
I found some help in the forum for similar problem but only for ICEM CFD by blocking the domain, but nothing about a case like this with ANSYS Meshing and multizone method.
Thank you for any tips!
supercolli is offline   Reply With Quote
Old   March 10, 2013, 17:35
Matteo Colli
Hi to all, no suggestions?
Old   July 9, 2014, 13:20
Default specifying inflation
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I too stuck in the same problem
Shamoon Jamshed is offline   Reply With Quote
[ANSYS Meshing] Error in setup after meshing (fluid & solid) zlaugh ANSYS Meshing & Geometry 0 December 8, 2012 12:34
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 02:18
How to create a fluid volume inside a solid volume sanin FLUENT 4 November 13, 2008 15:17
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
