March 14, 2013, 11:32 |
Need help with meshing
Rep Power: 13 |
Hi, I've been working on a project involving a 3D model of a room with two inlets and two outlets. In the end I want to track particle movements and concentrations of different gases. I meshed each imprinted inlet and outlet and then I meshed the body as a whole.
My question is, how can I create a finer mesh where the velocity is high and a coarse mesh where the velocity is low? I want to have my solution converge and right now it does not. I'm also using the student version which reaches a maximum of 512000 cells, so I want finer mesh only where it is necessary. In the picture you can see where the velocity is high and where it is low. not sure if the picture worked so here is the link. http://imgur.com/vAHniNA Thanks. |
March 17, 2013, 14:28 |
Rep Power: 13 |
Is there anyone that can help me? I would like to mesh the bottom halfof the room with a fine mesh and the upper half with a coarse mesh. Does anyone know how to do this?
March 17, 2013, 14:45 |
Rep Power: 13 |
can you be more specific?
March 17, 2013, 15:12 |
Rep Power: 13 |
I would like to have a min element size of about 0.05 and a max of about 0.1.
March 17, 2013, 17:26 |
Rep Power: 13 |
Say if you want to refine only bottom half of the room, draw a cube of its dimensions in the design modeler. In ansys meshing,use sizing function -> body of influence- > select the cube -> give the element size for refinement.
March 17, 2013, 17:41 |
Rep Power: 13 |
Ok, thanks for your response.
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
