[ICEM] Problems with meshing a 3D wing w/winglet |
March 17, 2013, 16:13 |
I'm having problems meshing a 3D wing with a winglet using hexa-mesh. I finished the blocking and ran a quality check for premesh based in determinant and angle criteria and obtained above 0.4 and 19º, respectively. Then I proceeded to convert the premesh to an unstructured mesh. After the mesh was generated, I ran a quality check for all the cells based in determinant, min angle, and orthogonal quality and obtained above 0.4, 19º, and 0.35, respectively. The problem here is that Icem is printing a message about 5028 cells with undefined quality during each check. I also did a check for problems finding out that there are 10 penetrating cells that can be fixed without improving the issue about the undefined quality cells. Geometry and blocking files are below: https://www.dropbox.com/s/hw85r1x1n8...luidDomain.tin https://www.dropbox.com/s/uffxplfl5x...013_Coarse.blk Does anybody know how to locate these undefined quality cells in order to fix them? I need to solve this since the mesh is giving me problems in Fluent because they are detected as cells of low orthogonal quality (below 0.01) and I blame these ones to the instability and difficulty to convergence of numerical solution. I hope someone can help me out with this since it is part of my dissertation and I'm running out of time. Thanks in advance, César |
March 17, 2013, 16:54 |
Alexander
Hello, Cesarcg!
You blocks is very good! You should try check your grid by determinate 3x3x3 in rang -1 to 1. I think you will see your error there. Pospelov Alexander |
March 17, 2013, 17:20 |
#3 | |
Thanks for your suggestion but I already did that and didn't find the error. I ran out of ideas to look for the problem. Regards, César |
March 17, 2013, 18:32 |
Alexander
If you delete part solid, you would not have any problem in ICEM. I've done all checks in ANSYS 13.0.
But it's takes me some time, because I've got not good computer at home. ) Pospelov Alexander |
March 18, 2013, 09:55 |
Ghazlani M. Ali
Rep Power: 28 |
Still i think tetra+prism is more suitable for this. multizone will be the best. a premesh info inform me that you have generated 9 000 000 nodes. you really need some strong hardware there to simulate this...
March 18, 2013, 10:25 |
Rep Power: 24 |
One possible solution could be to deactivate line_2 elements while running quality checks. Quality is of course not defined for line elements.
March 18, 2013, 11:42 |
#10 | |||
Thanks for your suggestions. I followed what you've recommended but I just figured out that my problem may not be because the part solid present during unstructured mesh generation neither the translator to mesh for fluent. I ran the mesh quality check before and after export the mesh to fluent and ICEM and got the same minimum values for the different criteria (min angle=21.4º, min determinant=0.35, and min orthogonal quality=0.24). So I guess there is no problem with ICEM. I think this values are good enough to run the simulation with no big problems, but when read the mesh in fluent, it prints that the orthogonal quality mesh is low (7.35845e-3). I think that I should make a check with gambit and see what it tells. Quote:
Hope that you are doing great. Can you tell me where the number of nodes can be reduced according to your experience? I know that there are some regions that can be improved and your advices would be very helpful. Quote:
I did what you suggested and you are right. I didn't know that. Thanks a lot. --------------------- Thanks to everyone, César |
March 18, 2013, 12:12 |
#11 | ||
hexa meshing, orthogonal quality, winglets, wings |
meshing for flapping wing simulation | sultan | FLUENT | 5 | February 17, 2013 08:31 |
3D wing + wind tunnel hexa structured meshing | icemaniac178 | ANSYS Meshing & Geometry | 9 | October 28, 2010 09:37 |
Meshing for 3D wing with tubercle on the leading edge in GAMBIT | nvtrieu | FLUENT | 0 | August 14, 2010 10:13 |
Meshing problems using Gambit | Vianney | FLUENT | 4 | May 30, 2009 03:45 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
