[ICEM] Meshing sinusoidal leading edge wing in ICEM
Like Tree3Likes
Old   March 4, 2013, 13:55
Default Meshing sinusoidal leading edge wing in ICEM
ryerson_guy is on a distinguished road
Hi there,
I am trying to mesh a wing which has sinusoidal leading edge and so far have been struggling with the mesh. I would like to know if I should use an O-grid block or a C-grid. I tried to use a C-grid and the resulting mesh has a lot of errors. I am attaching my project files. I want to use symmetry boundary conditions on both sides of my model (wing modeled as an infinite wing) . Please help me out thanks.
ryerson_guy is offline   Reply With Quote
Old   March 4, 2013, 22:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/ans...-geometry.html
Far is offline   Reply With Quote
Old   March 5, 2013, 00:37
Far
Sijal
Hey this is what I got on your case in 10 minutes. Hope it helps you...
https://dl.dropbox.com/u/68746918/Tubercle_all_far.rar
https://dl.dropbox.com/u/68746918/Tubercle_Far.zip
PS: Upload on dropbox may take some time, meanwhile you may encounter error 404
ryerson_guy likes this.
Old   March 5, 2013, 03:05
Hi Far,
Thank you very much for helping me out. I will learn from your blocking strategy and if I come across any trouble i'll post again. Thanks again I really appreciate your help.
Old   March 5, 2013, 04:05
Far
Sijal
You will notice that I have divided surface of wing into four parts (arbitrarily at 25%, 50% and 75% spanwise locations). I don't know why ICEM likes this way of surface in blocking and recently I happen to solve similar in following thread with this method of surface division.
http://www.cfd-online.com/Forums/ans...m-meshing.html
PS: This may not be the actual issue, it may be just my illusion.
Old   March 5, 2013, 04:07
Hi there,
May I know how were you able to extract curves from surfaces? It seems like you generated the airfoil sections in the middle and one on each sides. I tried to use extract surfaces from curves options in geometry and have been unsuccessful.
Old   March 5, 2013, 04:13
Far
Sijal
Geometry > Create/Modify curve > Iso curve methods (fourth from left in first row)
To split surface : Geometry > Create / Modify Surface > Segment Surface (third from left in 2nd row)
Old   March 5, 2013, 04:35
were you able to get the trailing edge points perfectly or you manually drew them? because i am unable to project trailing edge curve from above options
Old   March 5, 2013, 07:15
Far
Sijal
Ok. For one surface on trailing edge , I changed parameter from u to v (used same values i.e. 0.25, 0.5 and 0.75). Then I go back to geometry > create point > curve ends (first from left in 2nd row)
ryerson_guy and boss2011 like this.
Old   March 6, 2013, 00:15
Thanks for your help. Using your method I was able to generate a nice grid for my geometry. The thing is I shall be adding more tubercles (image attached). From your experience would you recommend using the same blocking strategy?
I also read the posts you referred earlier regarding 'mesh unable to follow curved geometry'. Unfortunately the project files are not there any more and I have nothing to refer. Please advise.
Old   March 6, 2013, 00:21
Far
Sijal
Same strategy would work perfectly. Re-use same blocking and increase no of nodes on the high curvature areas to capture them properly. Try and come back if you get any problem.
And good luck with your optimization work.
I have those files, but it would be better to ask the primary source Ananthakrishnan.A.S (through pm) to give you files and his thesis. He got the wonderful results for his optimization work.
Old   March 6, 2013, 00:28
Far
Sijal
Look for files in this thread http://www.cfd-online.com/Forums/ans...take-mesh.html
Old   March 15, 2013, 04:37
Stuart
ShowponyStuart is on a distinguished road
Hi, I'm working on a similar project myself and have been using the ansys mesher mesh it for me. I have been fighting it the whole time trying to generate a nice mesh so I started investigating ICEM.
I have gotton as far as being able to mesh a 3d wing with some sort of success (I think)....but still not quite good enough. How hard would it be to learn how to block like you have for this wing. Ultimately my aim would be to be able to use a script to import the geometry and the (judging by the blocking you have done) input how many nodes so you can use geometry with various amplitudes and wavelengths.
Would it be possible to outline how you blocked this in simple enough terms for an idiot to understand? I understand what youve done in terms of blocking approach, Im just not sure how to achieve it exactly.
Usually I would take more time to learn it thoroughly...but its very late into the project. I would probably spare 2-3 full days learning if I need too, but I cant spend much more then that as I need to keep simulating.
So any chance of a bit of a walk through, or will it not be worth it?
ShowponyStuart is offline   Reply With Quote
Old   April 8, 2013, 03:48
Hi there,
I followed your method and was able to obtain the grid for the case where the amplitude was reduced, however, for the case where amplitude was increased, mesh started to have negative elements. The same goes for the case where the I increased the wavelength. I see some elements penetrating into surface and moved some vertices but didnt help. Would you please mind helping again?
The files are in the link below:
https://www.dropbox.com/s/xcbsri1gin...e_0.5cwave.rar
https://www.dropbox.com/s/t6a383tkfh...rcle_0.15c.rar
Old   April 8, 2013, 03:50
Stuart
did you change "project face" to "project edge"? Right click in premesh to change that and see if that helps.
Old   April 8, 2013, 03:54
I tried but it has to do with mesh quality, which is irrespective of projecting edges or faces, which is less than zero in my case.
Old   April 8, 2013, 04:06
Far
Sijal
Stuart: do you still need help? I missed this one as I was busy with my course (renewable energy)
ryerson_guy: please post some pics....
Old   April 8, 2013, 04:07
Stuart
Hey man,
Just had a look and saw how you were doing it. I actually do mine differently (on the advice of FAR) I dont bother splitting the blocks in the spanwise direction. I just associate the leading edges to a curve on the wing to the a single block.
I dont think it captures the geometry perfectly, it seems pretty robust.
Im not sure if I explained that particularly well but here is one of mine for you too look at. You may need to "project to edge" like I said before to see what it will normally look like (for some reason default is set to project to face)
https://www.dropbox.com/sh/b7wxg12rylbw169/s44uwEe1Fh
Old   April 8, 2013, 04:08
Stuart
Hahaha, thanks FAR but you already helped me HEAPS in this thread. (which might be useful to you too ryerson_guy
http://www.cfd-online.com/Forums/ans...edge-wing.html
Old   April 8, 2013, 04:44
Pics are attached.
ICEM Hexa meshing tutorial - Wing with sharp trailing edge Far ANSYS 1 May 18, 2012 14:19
[ANSYS Meshing] Hybrid meshing ICEM djoul ANSYS Meshing & Geometry 2 January 17, 2012 18:18
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 14:26
Meshing for 3D wing with tubercle on the leading edge in GAMBIT nvtrieu FLUENT 0 August 14, 2010 10:13
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
