[Other] Assigning two faces separate NS on same surface |
April 6, 2021, 07:49 |
Rep Power: 8 |
Hello all,
I am trying to assign NS to two faces on the same surface within Solidworks, but am not able to do so. The blue region without the circle is to be plate-walls while the circle should be inlet. If I do not define these two then there is an overlapping on the fluent import. Could anyone suggest how can I make the circle, as a separate surface, while the remaining as a separate clickable surface? |
named selections, overlapping, surfaces |
[snappyHexMesh] No generation of layer onto zerothickness surface | crubio.abujas | OpenFOAM Meshing & Mesh Conversion | 3 | October 25, 2022 03:20 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
