[DesignModeler] modeling
Old   May 1, 2013, 16:18
Default modeling
Sa.Baraty
sara22 is on a distinguished road
hi friends. I want to modeling 3D pipe with constant temperature at outer surface, and fluid flow at inner of tube. i sketched it in DM (Ansys).so i have 2 bodies 1 pipe and 2 is fluid flow.when i mesh it and export to fluent, in boundary condition i have extra surface.how i can coupled between fluid surface and pipe?
thanks
sara22 is offline   Reply With Quote
Old   May 2, 2013, 09:10
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
can you share some pictures ? the project ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 2, 2013, 12:37
Sa.Baraty
I have 2 geometry 1 pipe and 2 fluid that flow in tube.i sketched it in DM. i use from Ansys Mesh. in ansys mesh i define 3 face as inlet outlet and body of tube.but when export to fluent i see this situation as boundary condition
body of tube
outlet
inlet
fluid
solid
interior-fluid
interior-solid
wall-fluid
wall-solid
Old   May 2, 2013, 17:32
diamondx's Avatar
Ghazlani M. Ali
everything which is 3d is considered as interior-fluid...
Regards,
Ali
Radiation modeling michael_owen Main CFD Forum 1 February 26, 2013 16:53
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
